Old 08-20-2019, 06:02 PM   #1
keyswitch1
Default Carb problims
I have a zenith carb on my 1930 model a for at least 20 years. Now all of a sudden it will leak a lot of gas around the filter valve up front where the strainer part goes into. It has a new gasket on it. I do not try to start it but at a lost for how to correct the problems. Any ideas ?? Thank you in advance !
keyswitch1 is online now   Reply With Quote
Old 08-20-2019, 07:12 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Carb problims
O-ring? No o rings on zenith carb
www.whidbeymodelaclub.com
Old 08-20-2019, 07:13 PM   #3
ryanheacox
ryanheacox's Avatar
Maybe replace the entire strainer and the gasket? Strange that it would happen all of the sudden.
Old 08-20-2019, 07:31 PM   #4
keyswitch1
I have replaced both parts ad there is no change.
Old 08-20-2019, 07:40 PM   #5
Jerry Kzoo
Jerry Kzoo's Avatar
A couple of thoughts:
The threads of the carb upper casting might have some deterioration due to rusting and age. Back off the strainer 1/2 turn and see if there is wobble.
The gasket material is not in itself able to stop the flow of fuel.
I have a set up to test the fuel shut off and have found this area to be prone to leaks. I have had to put some thread sealer on there and/or really snug up the strainer.
Make sure the casting is not cracked from over snugging the strainer
Jerry
Jerry Kzoo is offline   Reply With Quote
Old 08-20-2019, 08:20 PM   #6
Joe K
Joe K's Avatar
I might put this one to the compression fitting where the gas line ties into the carb. This one is adjacent to the fuel filter and the fittings as being provided by the parts people are particularly poor quality.
Now everyone seem to has replacement gas lines with the fittings included - these are compression in theory, have a "shear off" seal ring made as part of the hex, emulate perfectly the original two piece (hex fitting and seal ring) when in place, but in my experience, leak like a sieve.
You can buy the old fashioned hex fitting and ring separately - most don't because they're handed the one piece hex/seal and "why do I need a better fitting when one is included."
I'll take a leak tight gas line for $200 Alex. Maybe that's reason enough?
Joe K
Shudda kept the horse.
Joe K is online now   Reply With Quote
Old 08-20-2019, 08:37 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I wouldn't pay $200, but I agree with Joe that the separate ferrule is the way to go.
Old 08-20-2019, 09:07 PM   #8
Gary WA
Gary WA's Avatar
Possible crack as noted and hard to see!
Old 08-20-2019, 09:10 PM   #9
Gary WA
Gary WA's Avatar
photo of leak area?
Old 08-21-2019, 12:49 AM   #10
30 Closed Cab PU
Sealer is not recommended anywhere on a carb, it will only mask the real problem. Sealer if used on a carb also has a tendency to dissolve/deteriorate and cause other issues like clogging carb jets/passages.
Old 08-21-2019, 02:33 AM   #11
johnbuckley
johnbuckley's Avatar
I've never had any problem with a thin smear of blue hylomar on gaskets for 90 year old carbs! this problem in OP #1 could be as others have said fuel inlet union .
johnbuckley is online now   Reply With Quote
Old 08-25-2019, 11:32 AM   #12
keyswitch1
I bought a new fuel line from Brattons and the problem is fixed.
Old 08-25-2019, 07:32 PM   #13
30 Closed Cab PU
From my experience. Once the sealer has set up and seals all may be OK, but if the seal is tightened or the part is taken loose the sealer can break apart/up. So it is best if using sealer to completely clean it completely, and reapply fresh if adjusting, or taking things apart. I had small bits of hardened sealer get into the passages, jets, wells when I took apart a carb, did not get rid/clean of all the old sealer out of the carb before reassembling.
