Old 06-22-2019, 02:18 PM   #2741
LazarusLong
LazarusLong's Avatar
Default Re: What I Did on My Lunch Hour
Originally Posted by Vic Piano View Post
Pete, that's a '68 Jag XKE Series 1.5 that my dad bought new. I pulled the gas tank out to clean it. The car needs brakes, etc. before I brought it down to Florida (unbeknownst to me) my dad had let it sit in an old chicken coop for several years so it now needs an interior and top as well. Here's another photo of it.
A 6 cylinder XKE roadster has always been one of my dream cars.
LazarusLong is offline   Reply With Quote
Old 06-26-2019, 03:38 PM   #2742
Vic Piano
Vic Piano's Avatar
https://www.fordbarn.com/forum/attac...1&d=1561581458
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 08-05-2019, 01:58 PM   #2743
Vic Piano
Vic Piano's Avatar
https://www.fordbarn.com/forum/attac...1&d=1565031504
Old 08-05-2019, 02:14 PM   #2744
Vic Piano
Vic Piano's Avatar
I haven't been posting on the FordBarn for a while, busy working on the second annual Cigar City Concours d'Elegance. At this point I'm not sure what we are going to do about the annual Barner's Bash aka the Winterfest. But this is a tech question: I installed a (set up by Skip Haney) distributor and rebuilt OEM coil several months ago in the '39 CS and everything has been fine until about two weeks ago when I discovered a split in a section of fuel line, letting air get into the fuel. I fixed that problem and now the engine will fire up and idle just fine, it even accelerates in first and second gear (up to a point) if I push it beyond the normal shifting rpm range is starts to break up. In high gear it's fine at lower rpms but, when I try to accelerate, it starts breaking up Looking for answers, solutions, suggestions. I've checked all electrical connections in the charging system and (I have not let any smoke out of the wires ) so I'm at a loss.
Old 08-05-2019, 02:35 PM   #2745
adileo
adileo's Avatar
Vic
I had similar problem. Pulled plugs - clean - re-gapped also cleaned air cleaner and issue went away.
Another thought - condenser
Thanks
Andy
1939 Deluxe coupe
1952 F1
adileo is offline   Reply With Quote
Old 08-05-2019, 04:13 PM   #2746
Vic Piano
Vic Piano's Avatar
I haven't checked the plugs, guess I'll give that a try.
Old 08-06-2019, 09:41 AM   #2747
LazarusLong
If you are running Champion plugs,throw them away and replace them with any other brand.
Old 08-06-2019, 05:08 PM   #2748
Vic Piano
Vic Piano's Avatar
I haven't used Champion Spark Plugs in almost 40 years. I run Autolite 216's.
Old 08-06-2019, 05:35 PM   #2749
KiWinUS
KiWinUS's Avatar
Love Champions
Blame all you want Champions are not your problem
Please let common sense prevail
And that’s from an “American “ (as of today)
Hell Yea
Old 08-06-2019, 05:53 PM   #2750
Vic Piano
Vic Piano's Avatar
Congrats Tony! I stopped using champion plugs back in the '80's when I went to get eight for my '53 Ford. Got home, opened up the package and six of the eight plugs didn't have the ground electrode on them. Poor quality control. That may be a thing of the past but I've never had a problem with Autolite 216's.
Old 08-06-2019, 06:22 PM   #2751
LazarusLong
Originally Posted by KiWinUS View Post
Love Champions
Hell Yea
Why can't I blame Champions,when I buy 8,put them in a stock 51 Ford.and 3 of them die within a week?
Switched over to Autolite and never had another problem.
I have seen them fail in other cars,also.
Old 08-06-2019, 07:04 PM   #2752
Steves46
Steves46's Avatar
Vic, it sounds like a fuel starvation issue at higher RPMs. How do the other fuel line connection points look throughout the system, electric fuel pump and mechanical fuel pump pass through connections?
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 08-06-2019, 07:30 PM   #2753
40cpe
40cpe's Avatar
Love Champions
Hell Yea
Good on you, Tony! Congratulations (I think)
Old 08-06-2019, 07:44 PM   #2754
KiWinUS
KiWinUS's Avatar
Geez mate not sure how my engines can be so screwed up that they run so well on Champions!
I must be doing something really wrong. I must need educating on something. Just not sure what.
Old 08-06-2019, 07:44 PM   #2755
KiWinUS
KiWinUS's Avatar
Thanks so much Gene
Old 08-06-2019, 07:45 PM   #2756
KiWinUS
KiWinUS's Avatar
And Thank you my great friend Vic
Old 08-06-2019, 08:14 PM   #2757
Vic Piano
Vic Piano's Avatar
I did have a small split in one section of rubber hose in the fuel line. I replaced all those sections, even put a late model fuel pump (with the sediment bowl) that I converted to a pass through. Not showing any air in the lines (no bubbles in the bowl) the only other thing I can think of is the fuel pressure regulator, I had it set at 2.5 psi. I'll put the car up on the lift tomorrow and check to make sure the setting hasn't changed. More fun with Flatheads.
Old 08-06-2019, 08:16 PM   #2758
Vic Piano
Vic Piano's Avatar
You are most welcome my friend. That is quite an accomplishment, something to be very proud of for sure.
Old 08-16-2019, 09:25 AM   #2759
Vic Piano
Vic Piano's Avatar
https://www.fordbarn.com/forum/attac...1&d=1565965534
