Old 12-25-2018, 10:17 AM   #21
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: 34 stock looking alternator
Originally Posted by Dave/Green Bay View Post
Isn't the casing a little larger that a stock generator? Dave/Green Bay
Yes Dave, the center casing is just slightly larger in diameter as compared to original. Other than that, it looks identical to the original generator, including a non operative cutout mounted on top.
John
Old 12-26-2018, 08:52 AM   #22
G.M.
If you want a 6 volt alternator to charge at idle you need a
24 volt stator and you can use the large stock Ford pulley. I
used an adjustable voltage regulator with a small hole in the
rear cover plate so I can set the voltage at idle. I made 7 of
them for my cars and never had any problems. Once you had
an alternator you wouldn't want to go back to a gen. G.M.
www.fordcollector.com
Old 12-26-2018, 07:42 PM   #23
bobgc
bobgc's Avatar
I have one from Powermaster on my 34 pickup and it works fine. It is a bit bigger in Diamater and I had to make the pulley fit the shaft in order to use the original one. I believe they now have fan pullies available. take the cutout apart and solder the points closed so the juice goes straight thru.
bobgc is offline   Reply With Quote
Old 12-26-2018, 10:30 PM   #24
al's28/33
al's28/33's Avatar
Can someone running the Whitney alternator post a picture here ???????????????
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 12-27-2018, 12:02 AM   #25
JSeery
JSeery's Avatar
It looks like the original, because it is the original except for the center case. There are several photos on their web page (post #2 has a link). I can post a photo of one setting on an engine tomorrow.
Old 12-27-2018, 12:10 AM   #26
JM 35 Sedan
It would look exactly like the original generator used in production on whatever year vehicle you are interested in, because the alternator is installed inside the original generator housing, except for the center casing which machined from aluminum, and is just slightly larger in diameteI as compared to original.
......and I could post pictures of my original generators tomorrow that would look identical to a Whitney alternator conversation
John
Old 12-27-2018, 07:40 AM   #27
john in illinois
john in illinois's Avatar
t
Here you go. I had one made without cut out.You get whatever you want.
File Type: jpg 52EB5857-4B3F-47C7-A7DA-E20D806D1F31.jpg (67.2 KB, 56 views)
john in illinois is offline   Reply With Quote
Old 12-27-2018, 01:49 PM   #28
JSeery
JSeery's Avatar
Here are some photos of a Whitney alternator I current have setting on an engine. It is a late 40s Generator conversion. Whitney will build them like you want them, I wanted the original three wire style. Others have commented on the case being slightly larger in diameter, don't believe that is the case in the ones I have dealt with. Not sure how clear it is in the photos, but the case is slightly smaller in diameter than the original ends. BUT, I have not measured the two side by side.
