02-10-2018, 09:42 PM | #1 |
Unknown parts from 1930 Cabriolet or not...
Found in a bucket from the people who dismantled my 1930 car who seemed to have problems sorting out what was taken off from where or even if it was from my car.
I do not even know if this is from a Model A, but it is a strong metal plate and long bolts so if anyone knows what it is let me know as it seems important for something. Thanks, Kim
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930. |
02-10-2018, 09:46 PM | #2 |
Re: Unknown parts from 1930 Cabriolet or not...
That has the shape of a door hinge backing plate. I am not familiar with the cabriolet body structure, so not sure if that is correct, but it may fit behind the wood pillar to where the door hinge attaches.
02-10-2018, 09:48 PM | #3 |
Not sure of your deminsions but there is a plate on top of the header that the folding irons attach to/they the wooden header
If the bolt pattern is same as front of the folding iron, could be. It is a three-bolt pattern |
02-10-2018, 09:49 PM | #4 |
I believe the metal plates go on the wooden header on the opposite side of the front of the folding irons . If you have the folding irons match the metal plates and screws with the holes in the top irons . Norm
02-10-2018, 10:08 PM | #5 |
Norm is correct
02-11-2018, 10:02 AM | #6 |
02-11-2018, 10:37 AM | #7 |
Things would be WORSE, if the bucket had a BIG hole in it.
Bill Leaking
02-12-2018, 08:45 PM | #8 |
So for Cabriolet owners in judging. Should I paint this plate upper body color (Seal Brown) in my case, but since it has screws through the top irons should they be nickel plated?
Thanks, Kim
02-12-2018, 10:36 PM | #9 |
just put some protection on the nut plates like a good bear metal primer. when the top material is installed you will never see them again until you remove the top material.
02-19-2018, 06:49 PM | #10 |
JW,
Thanks so much. Do the bolt heads still show when mounting the brackets? I can see the other side is covered but should I nickel plate the bolt heads? Thanks again. Kim
02-23-2018, 01:02 PM | #11 |
The slotted flat head screws show when the top is down. Yes, or use stainless
02-23-2018, 10:31 PM | #12 |
Bill is right on. I use polished stainless.
