Old 02-12-2018, 10:23 AM   #21
SeaSlugs
SeaSlugs's Avatar
Default Re: Exhaust manifold finish?
Originally Posted by burner31 View Post
About three years ago
And yes I know...the intake is white. I like it like that
Is that cast blast? Looks more like the high heat BBQ paint. My current waffle manifold is painted with that stuff and holding up great but my new repo exhaust manifold id like to keep the cast look to it.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-12-2018, 10:48 AM   #22
burner31
burner31's Avatar
Very good eye there SeaSlug.
Yep, high heat BBQ paint, works great, lasts long and won't break the bank.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 02-12-2018, 01:34 PM   #23
Purdy Swoft
Purdy Swoft's Avatar
I wire brushed the rust off a used manifold and painted it with Cast Blast . I let the paint cure on the shelf untill I was ready to use it . The manifold still looks purdy good after 12 years . I figured that there was no need in spending much on manifold paint . In some cases the manifold will need replacement before the paint completely fails .
Old 02-12-2018, 01:50 PM   #24
29er
29er's Avatar
Anybody use "Calyx Manifold Dressing"? Saw it online and wondered how it compares with other paints mentioned in this thread:
http://www.snydersantiqueauto.com/manifold-dressing
29er is offline   Reply With Quote
Old 02-12-2018, 09:17 PM   #25
1crosscut
1crosscut's Avatar
Here is a couple pictures of one I just finished using cast blast.
Dave
It'll feel better when it quits hurting.
1crosscut is online now   Reply With Quote
Old 02-12-2018, 09:35 PM   #26
SeaSlugs
SeaSlugs's Avatar
oooh shes purdy. Im sold! How did you guys cure it? Ive got all the time in the world as its Feb in central IL. So wont be messing with manifolds till i dont need to wear gloves. Time and letting it sit in a warm house or does it need to be cured in an oven?
Also is 1 can just enough for one manifold? i have 2 manifolds i need to paint and unsure if one can will be enough...
Old 02-12-2018, 10:07 PM   #27
1crosscut
1crosscut's Avatar
You can probably do two manifolds with one can. It'll be close.
You can cure it in an oven or a barbecue grill. I use a propane torch and play it over the manifold while checking it with a laser thermometer. You have to get it to at least 400 degrees to cure it. If you get up closer to 500 it will begin to smoke some.
I did my first one in the oven at home. Glad my wife was away on a business trip for a few days. Really stunk up the house.
Dave
Old 02-12-2018, 10:28 PM   #28
SeaSlugs
SeaSlugs's Avatar
Noted on the oven haha. Hmm i got an old bbq grill that can be used. Has anyone found this stuff in a store? I plan to check Big R, TSC, Farm N Fleet, Ace, and some of the auto parts places. I coulda sworn ive seen it somewhere.
Old 02-13-2018, 02:31 AM   #29
Mike V. Florida
Mike V. Florida's Avatar
Nothing was used from the factory. It was plain cast, hence the use of the "cast blast" coating to simulate the look of just cast iron.
Old 02-16-2018, 02:58 PM   #30
SeaSlugs
SeaSlugs's Avatar
https://streettechmag.com/2015/05/04...aust-manifold/
found this article using slip plate - looks nice. Not sure on the longevity or if everytime you touch it comes off on your fingers...
Old 02-16-2018, 03:14 PM   #31
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Model A Suppliers sell CAST-BLAST.
"THE ASSISTANT GURU OF STUFF"
Old 02-17-2018, 02:30 PM   #32
Dan Partain
Dan Partain's Avatar
I used cast blast on a manifold last summer, here's a photo. It's not a wrinkle finish. I haven't cured it in any way yet, I just put it on the engine which I'll be getting started in a few weeks.
Dan Partain is offline   Reply With Quote
Old 02-17-2018, 10:55 PM   #33
SeaSlugs
SeaSlugs's Avatar
IS that a special manifold that is missing the bolt holes for the intake? Looks great otherwise
Old 02-18-2018, 07:03 AM   #34
Tom Wesenberg
Tom Wesenberg's Avatar
Looks like tape on the area, though I'd paint everything.
Old 02-18-2018, 01:16 PM   #35
Dan Partain
Yep, masking tape painted with Cast Blast hiding the holes.
Thread Tools
Display Modes
