Old 02-12-2018, 11:40 AM   #1
barkleydave
barkleydave's Avatar
Default Motorcraft Oil Filter FL-14
Have a valve cover mounted oil filter on a 31 Slant.
Has a Motorcraft FL-14 oil filter.
Will a NAPA 1515 fit?
Unable to locate the Motorcraft is a very old number.
Thanks
barkleydave is offline   Reply With Quote
Old 02-12-2018, 12:03 PM   #2
Bob C
Default Re: Motorcraft Oil Filter FL-14
Must really be an old number, I looked in a 1975 filter catalog and it's not listed.
Bob
Old 02-12-2018, 12:12 PM   #3
Jim Baskin III Pa.
Jim Baskin III Pa.'s Avatar
I have the same setup as you Dave and I use NAPA Gold 1068
Jim Baskin III Pa. is offline   Reply With Quote
Old 02-12-2018, 12:51 PM   #4
Paul Mike
Paul Mike's Avatar
Are you sure it is not a FL-1A? I am building an engine with that set up and it came with a Motorcraft FL-1A. That is a common filter you can get just about anywhere.
Paul Mike is offline   Reply With Quote
Old 02-12-2018, 01:14 PM   #5
katy
katy's Avatar
Fram PH8A
Talk slow, think fast.
Old 02-12-2018, 01:42 PM   #6
Curtis in MA
Mine also used the Fram PH8A but I couldn't get it.
Curtis in MA is offline   Reply With Quote
Old 02-12-2018, 02:12 PM   #7
Fullraceflathead
Fullraceflathead's Avatar
Don't use Fram as they are junk inside. All paper and hot glue.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-12-2018, 02:22 PM   #8
CarlG
CarlG's Avatar
Wix 51515
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-12-2018, 02:55 PM   #9
barkleydave
Thanks NAPA 1515 same as WIX
Old 02-12-2018, 04:39 PM   #10
Fullraceflathead
Wix is one of the Best and they make many for other companies.
-Henry Ford
1941 Willy's Pickup
Old 02-12-2018, 04:44 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
That doesn't make any sense. How can Fram remain one of the leading filter manufacturers if they sold "JUNK".
Y-Blockhead
'30 Briggs Town Sedan
_________________________________
And once again that is just my 1 worth.
Old 02-12-2018, 05:12 PM   #12
klawockvet
klawockvet's Avatar
They may be leading a leading sales manufacturer but are far from a leading quality producer. They are big because they are cheap and sold by every discount place in the world. I used them as a youngster because my family did but I stopped when the inside collapsed on a race motor many years back. Now Ionly use OEM and Wix. I have used Napa Gold in a pinch in engines I'm not that fussy about.
klawockvet is offline   Reply With Quote
Old 02-12-2018, 05:17 PM   #13
Tom Endy
Tom Endy's Avatar
These are all interchangeable and will work on the after market side cover oil filters for the Model A:
Pennzoil PZ-1
Fram PH8A
AC PF-2, PF-20
Motocraft FL-1A3
Napa 1515
Lee LF-2
Tom Endy
Old 02-12-2018, 05:58 PM   #14
Y-Blockhead
Originally Posted by klawockvet View Post
They may be leading a leading sales manufacturer but are far from a leading quality producer. They are big because they are cheap and sold by every discount place in the world. I used them as a youngster because my family did but I stopped when the inside collapsed on a race motor many years back. Now I only use OEM and Wix. I have used Napa Gold in a pinch in engines I'm not that fussy about.
Just for the record I use WIX filters. I'm just saying all the problems I have heard about Fram filters were from 15 years ago.
Y-Blockhead
Old 02-12-2018, 06:02 PM   #15
barkleydave
OOPS F-1A
1515 was correct NAPA GOLD
Old 02-12-2018, 06:15 PM   #16
slammin
slammin's Avatar
On another auto site several guys with a lot more time than I have cut apart filters from all the manufacturers. You would be amazed at the difference in construction. I'm sure there are dozens maybe hundreds of threads knocking Fram filters. I suppose they do the job, but for a few extra bucks why not buy the best, WIX.
slammin is offline   Reply With Quote
Old 02-12-2018, 09:54 PM   #17
PalAl
PalAl's Avatar
Is it possible it could be a Motorcraft FL144 that was used on Jeep, Willys, Case, Ford, Hudson, Massey? Thought a number 4 may have worn off.
PalAl is offline   Reply With Quote
Old 02-12-2018, 10:51 PM   #18
Fullraceflathead
They spend millions in advertising and sponsorship.
If you look up oil filters you will see what a Fram looks like inside.
-Henry Ford
1941 Willy's Pickup
Old 02-13-2018, 09:18 AM   #19
katy
katy's Avatar
I've used many, many Fram filters over the last 50 years or so and never had a problem w/any of them.
BTW, are Kralinator oil filters still made? If so, does anyone use them?
Old 02-13-2018, 10:56 PM   #20
31a
I have also used fram for years with no problem, bottom line use what ever filter you want too it's your car Bob
31a is offline   Reply With Quote
