Old 09-26-2019, 09:54 AM   #1
Floats
Floats's Avatar
Default Welding a bead on the stub axle
Hi Gents,
Some time ago I saw a post suggesting welding a bead on the stub axles(outside of the king pin bushes) in order to shrink the bushes and tighten up the kingpins.
Could this be done with the kingpins and bushes in position, even with the stub axles in position?
I assume this is done with an arc welder, running a bead up the outside of the king pin mountings, on the stub axle?
Does this weld need to be cooled down after welding or must it be left to cool down naturally?
Your inputs are much appreciated.
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 09-26-2019, 11:21 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Welding a bead on the stub axle
I think the 'stub axles' that you are referring to are called Spindle Assemblies by Ford.
While I do not recall the post you are referencing, I don't think what you are suggesting is prudent.
Instead, the way I would suggest the repair be made is mount the existing Spindle Bolts (King Pins) into a lathe and use a Tool Post grinder to true them until they are round. Then fabricate a new bushing for the spindle and press it in. Next bore and finish hone the bushing to a size of about 0.001" over the new size of the Spindle Bolt. This allows you to have a good/safe repair that will last a long time.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-26-2019, 12:03 PM   #3
Floats
Floats's Avatar
Thanks Brent,
That has all been done, new king pins or spindle bolts and new bushes were fitted by a local engineering company.
The bushes were reamed and not honed with the result that they are not perfect and I assume the guy that did the job did not think a close fit was that important, being an old car.
As I mentioned, I have seen a post here where slight play could be fixed by a weld on the spindles.
Much appreciated.
Regards
Chris
Cape Town
Old 09-26-2019, 01:12 PM   #4
1931 flamingo
1931 flamingo's Avatar
Pull it apart, install new bushings and find a different shop and have them honed to the pins. Re-assemble. "local engineering company" , interesting.
Paul in CT
Old 09-29-2019, 07:41 PM   #5
dumb person
dumb person's Avatar
While i've done things like that on things that are not vehicle steering parts (E.G. farm equipment) i don't recommend it on vehicle steering parts.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
