Old 01-22-2019, 09:21 PM   #1
Beater
Beater's Avatar
Default brake parts and grease
I'm curious what you fellas do for the rollers and stuff, grease them? oil them lightly when assembleing? mine is bone dry all the cams and pins and such when I took things apart for inspection what does henry say to do back there?
Beater is offline   Reply With Quote
Old 01-22-2019, 09:27 PM   #2
J Franklin
J Franklin's Avatar
Default Re: brake parts and grease
Use grease designed for brake work sparingly.
Old 01-22-2019, 09:42 PM   #3
Beater
Beater's Avatar
ok. sounds correct. like the pins and stuff. what is correct stuff to use for the A?
Old 01-23-2019, 08:28 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Use disc brake grease, sparingly, with an acid brush. Lube all moving parts, that have metal to metal contact.
Bill W.
"THE ASSISTANT GURU OF STUFF"
BILL WILLIAMSON is online now   Reply With Quote
Old 01-23-2019, 03:43 PM   #5
Werner
Werner's Avatar
Picture attachement
Beste Gruesse aus Deutschland,
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 01-23-2019, 03:46 PM   #6
Werner
Werner's Avatar
Hello,
I use since some 10 years AFC Anti-Friction-Coat paint. That is a Molybdändisulfid mix. In USA manufactor is for example Dow Corning.
Recomennt dry it with hot air.
Picture shows grey coating.
Werner
Citroen 11 CV, 1947
Old 01-23-2019, 05:28 PM   #7
Brentwood Bob
Springs are incorrect. Hope that helps you.!
Brattons catalog has good diagrams of the correct assembly.
Brentwood Bob is offline   Reply With Quote
Old 01-23-2019, 05:34 PM   #8
Werner
Werner's Avatar
Hello Bob,
I am afraid; do you mean my car? On MAC's catalog I do not find a helping picture.
Werner
Citroen 11 CV, 1947
Old 01-23-2019, 07:07 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
Put the E brake C link pins in the other way, sort of a pain, but it will keep them from rubbing the drum
For lube I now use a Crest product called "ectolube" ,synthetic brake grease with high temperature drip point, 45 years ago I used white lubriplate, it's due now, it's been 45 years since I did more than adjusting, though the brakes work good
Old 01-23-2019, 07:22 PM   #10
Dan Partain
Dan Partain's Avatar
Sorry to hijack the thread regarding grease.
Werner, I though I should point out that your emergency brake carrier has been bent. It should be straightened out, or replaced. The emergency brake shoe should sit on top of the plate like the other end of the same plate.
Dan Partain is offline   Reply With Quote
Old 01-23-2019, 07:43 PM   #11
160B
160B's Avatar
Originally Posted by Werner View Post
Hello,
FWIW
The emergency brake toggle lever pins are not installed correctly, the pins are in backwards the cotter pin should be behind the lever. With the cotter pin outboard they will rub against the brake drum.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is online now   Reply With Quote
Old 01-23-2019, 07:46 PM   #12
Jim M
Jim M's Avatar
Just curious - what is wrong with the springs??
Jim M is offline   Reply With Quote
Old 01-23-2019, 07:51 PM   #13
160B
160B's Avatar
FWIW
I did not say anything about the springs, I noted that "The emergency brake toggle lever pins are not installed correctly, the pins are in backwards the cotter pin should be behind the lever. With the cotter pin outboard they will rub against the brake drum.
Old 01-23-2019, 09:18 PM   #14
Brentwood Bob
My bad. Looking for the long spring and the emergency brake carrier plate hides it. The drawing doesn't show the second small spring either.
Old 01-24-2019, 12:20 AM   #15
Y-Blockhead
Y-Blockhead's Avatar
That's what happens when you stop your car with the parking brake.
Y-Blockhead
'30 Briggs Town Sedan
'55 Ford Ranchwagon
_________________________________
And once again that is just my 1¢ worth.
Old 01-24-2019, 06:34 AM   #16
Werner
Werner's Avatar
Thank you for the important information about the wrong brake pad
assembly. I'm going to do therefore a new topic. -
Anti-friction coating, in contrast to grease has the great
advantage that it does not stick. Brake abrasion and dust are
not combined as pulp. The lubricating varnish is just a very
thin dry layer.
Werner
Citroen 11 CV, 1947
Thread Tools
Display Modes
