Old 01-14-2019, 09:23 AM   #1
chrs1961815
chrs1961815's Avatar
Default Gear shift boot removal
How do you remove the rubber gear shift boot?
chrs1961815 is offline   Reply With Quote
Old 01-14-2019, 09:42 AM   #2
Jw
Default Re: Gear shift boot removal
What?!
Jw is offline   Reply With Quote
Old 01-14-2019, 09:54 AM   #3
burner31
burner31's Avatar
If it seems stuck, I've seen where people have secured it under the cover plate.
Just remove the cover plate, shift knob and pull it up and off the lever.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 01-15-2019, 11:30 AM   #4
daveymc29
daveymc29's Avatar
It should just slide up the shifter lever. You obviously need to unscrew the shift knob to get it off the shifter. Someone may have installed a hotrod large dress up ring around it that could be screwed to the floorboard? That would have to be removed.
daveymc29 is offline   Reply With Quote
Old 01-15-2019, 12:11 PM   #5
JBill
If the floormat is installed and the boot is sticking up through it, I can see how it would not be immediately evident how to remove it.
JBill is offline   Reply With Quote
Old 01-18-2019, 11:46 AM   #6
Beater
Beater's Avatar
my boot split in very short order wish there was a better quality option
Beater is offline   Reply With Quote
Old 01-18-2019, 11:48 AM   #7
jwilliams81
jwilliams81's Avatar
You have to unscrew the shift knob from the shaft to remove it... hasn't been said yet.
1931 Murray Town Sedan. Black body with Apple Green pin stripe. Cincinnati, OH
jwilliams81 is offline   Reply With Quote
Old 01-18-2019, 12:12 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
See post #4... "You obviously need to unscrew the shift knob to get it off the shifter."
Y-Blockhead
'30 Briggs Town Sedan
'55 Ford Ranchwagon
_________________________________
And once again that is just my 1 worth.
Old 01-18-2019, 01:42 PM   #9
Joe K
Joe K's Avatar
Probably hard Argentinian rubber from the 1950s, now affixed to the chrome plating/rust/whatever.
Use a utility knife and "whittle" it off.
I recently took possession of a Model A engine and some miscellaneous parts which are probably "left overs" of a Model A restoration of the 1960s.
The engine looks like a "keepah" - rusty bore (he didn't put the head back on) but not much ring-ridge. I speculate in my mind this may be a "1st tightening" engine which may have all the original shims? It would be nice.
Other parts included a steering column anti-rattler - in the original plastic wrapper - label typewritten using a typewriter. Rick Freeman and his "How to Restore the Model A" books came to mind.
Bend the wrapper and and anti-rattle rubber inside cracks in two.
That one for trash.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 01-18-2019, 03:10 PM   #10
jwilliams81
It was hidden I tell you Or I am guilty of not reading all of the posts
Thread Tools
Display Modes
