Old 03-03-2018, 06:34 PM   #1
doug.nichols
doug.nichols's Avatar
Default Is this a 12v to 6v transformer?
What is this? This model a is a 12 volt setup and this gadget looks like it might be a transformer to convert 12 volt to 6 volt for the horn and possibly the headlights. It is taped to the water return tube. Does that make sense?
doug.nichols is offline   Reply With Quote
Old 03-03-2018, 06:47 PM   #2
AL in NY
AL in NY's Avatar
Default Re: Is this a 12v to 6v transformer?
NO. Looks like a high current resistor. Looks like it goes to the horn. You probably have a 12V system and this resistor is used to step the voltage down to 6Volts for the horn.
AL in NY
AL in NY is offline   Reply With Quote
Old 03-03-2018, 06:58 PM   #3
Jim in Wisconsin
Transformers do not work on direct current - only on an alternating or fluctuating current.
Jim in Wisconsin is offline   Reply With Quote
Old 03-03-2018, 07:18 PM   #4
doug.nichols
thanks Al
Old 03-03-2018, 11:23 PM   #5
eagle
eagle's Avatar
It's a wire wound resistor.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 03-03-2018, 11:31 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
What Al said!
Old 03-04-2018, 09:37 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
Attaching with tape a resistor that gets hot. Hmmmm?
Bob Bidonde
Old 03-04-2018, 09:58 AM   #8
katy
katy's Avatar
https://en.wikipedia.org/wiki/Transformer
Talk slow, think fast.
Old 03-04-2018, 12:37 PM   #9
Jemelton#
Jemelton#'s Avatar
Talking Re: Is this a 12v to 6v transformer?
Block Heater?
Jemelton# is offline   Reply With Quote
Old 03-04-2018, 08:58 PM   #10
doug.nichols
Think I will unwrap and relocate....
Old 03-05-2018, 09:38 AM   #11
katy
katy's Avatar
Ifn it's only used to feed the horn, then it likely doesn't see much use and would probably get more heat from the pipe than it would generate on it's own.
Thread Tools
Display Modes
