Old 02-27-2018, 06:30 PM   #1
kimeccles
kimeccles's Avatar
Default gas gauge in tank
So I took off the outer nut to rebuild the gas gauge and now not sure how to remove the rest of the gauge from the tank, out the front of the dash or out the top? It is stuck so not sure which way to move it.
LOL
engine/frame # late May1930, Briggs body actual build date # indicates late Aug/Sept. 1930 68B fixed seat Cabriolet
kimeccles is offline   Reply With Quote
Old 02-27-2018, 07:23 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: gas gauge in tank
Comes out the front. Replace the float with the new style and use CORK gaskets on the glass when you re-assemble.
Hopefully you dis-connected the battery first.
Paul in CT
Paul in CT
1931 flamingo is online now   Reply With Quote
Old 02-27-2018, 07:25 PM   #3
barnstuf
Before trying to remove it make sure the gas tank is close to empty and the battery disconnected. Then unscrew the instrument panel for full access to the gauge area.
The gauge comes out of the tank by pulling it towards you. It does NOT come out through the top of the tank, the gas fill opening.
barnstuf is offline   Reply With Quote
Old 02-27-2018, 07:27 PM   #4
kimeccles
kimeccles's Avatar
Thanks!
I don't have a battery installed until I get all the things sorted out and a fuse on the starter, but I assume cigarettes are also not recommended ....
Old 02-27-2018, 07:29 PM   #5
sphanna
sphanna's Avatar
AS barnstuf just told you, disconnect the battery!!! Once again, DISCONNECT THE BATTERY.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 02-27-2018, 07:30 PM   #6
sphanna
sphanna's Avatar
sorry, I did not see that you do not have battery installed
Old 02-27-2018, 07:31 PM   #7
Ted Duke
Unhappy Re: gas gauge in tank
Originally Posted by kimeccles View Post
thanks!
i don't have a battery installed until i get all the things sorted out and a fuse on the starter, but i assume cigarettes are also not recommended ....
boom!
Ted Duke is offline   Reply With Quote
Old 02-27-2018, 09:35 PM   #8
kimeccles
kimeccles's Avatar
Yes this car has had every nut and bolt removed at least once and most all aftermarket parts removed or waiting to be sold.
It does mostly look like it exploded (boom), but one day and one part at a time it is looking like a car again.
The inner nut is way harder to get out than the outer and so soaking in carb cleaner overnight and hoping for the best.
Old 02-27-2018, 09:41 PM   #9
kimeccles
kimeccles's Avatar
Also, what is correct for original gauge for judging? the gas gauge dial is etched numbers on aluminum I think, one of my numbers looked like black paint but all others are cleaned off or never were painted. Do the gauges need to have some gas resistant black paint in the 0, 1/4 and 1/2, F, notches for example? Or are they just left bare metal?
Old 02-27-2018, 11:42 PM   #10
J Franklin
J Franklin's Avatar
# are painted. I used catalyzed enamel, well cured.
Old 02-28-2018, 05:34 AM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Remove the pin and float arm, then clamp a 3/4" thick board in your vice. Set the gauge down on the board, like a saddle, then unscrew the inner nut. I soaked mine with Kroil.
Old 03-02-2018, 12:35 PM   #12
kimeccles
kimeccles's Avatar
Tom,
Thanks for your idea. I used a half inch wood dowel that just fit in between the gauge and that allowed it to be held tight. Then after 3 days of various soaking and liquid wrench I finally got it off.
So now, what type of sealant is recommended to put on the cork gaskets so they don't leak?
[IMG][/IMG]
Old 03-03-2018, 01:53 AM   #13
Tom Wesenberg
I put them together dry, but be sure to use cork, and NOT the black one.
Old 03-03-2018, 02:33 AM   #14
Mike V. Florida
Mike V. Florida's Avatar
Like Tom said none needed.
Old 03-03-2018, 11:08 AM   #15
redmodelt
redmodelt's Avatar
make sure the brass slip washers are in place when you assemble.
Old 03-03-2018, 06:32 PM   #16
old31
It helps if you put a little oil on the slip washers to keep the gauge from spinning when you tighten the nuts.
old31 is online now   Reply With Quote
Thread Tools
Display Modes
