Old 10-07-2014, 03:35 PM   #1
Tom B.
Default Stuck Brake Adjuster
I'm adjusting the brakes on my '30. The adjuster on the right rear won't turn. How do I free it up?
Tom B. is offline   Reply With Quote
Old 10-07-2014, 03:43 PM   #2
Joe K
Joe K's Avatar
Default Re: Stuck Brake Adjuster
It may be rusted in place. LOTS of penetrating oil - but be careful not to soak the brake pad.
Or possibly "tap" the end of the square while using an open end wrench on it.
Or - if all other means fail - do a tear down of this area removing the brake shoes and getting back to just you and the adjuster wedge. Then you can tap from both sides - and soak to your heart's content.
Heh. I almost forgot. On the inside adjuster housing there is a cap. This is usually removed by turning the adjuster in ALL the way and then tapping the now loose adjuster to where it "pops" the cap loose from the inside. Your adjuster is fixed in place so you'll have to find a way to pry out this cap. Maybe drill a hole in it and use a self tapping screw and a claw hammer to pry it out. (Slide hammer dent removers work real well on this too.)
New caps are available for small money. Or put the old one back with a hole in it.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 10-07-2014, 06:35 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Where do you live? Try to use a good quality brake wrech with a square hole so you don't round over the sides of the adjuster. I have one that I bought years ago at some swap meet. It's freed up a couple very stuck adjusters. You may have to use heat on the threaded cone part, and also use Kroil to help penetrate the threads. Be sure to grease the threads when it goes back together.
Thread Tools
Display Modes
