Old 10-08-2014, 02:51 PM   #21
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Muffler flange repairable?
Originally Posted by CarlG View Post
Looks like a roller bearing??
Roller bearing, ball bearing, it's still a muffler bearing.
Old 10-08-2014, 02:59 PM   #22
Pete
Pete's Avatar
What Tom said:
Poor quality surface weld.
Old 10-08-2014, 03:01 PM   #23
CarlG
CarlG's Avatar
I should have sent it to Pete, I guess.
But, whatever, it's still holding after several thousand miles.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-08-2014, 03:40 PM   #24
Pete
Pete's Avatar
I would have done if for nothing but you probably could have bought a new one for what the freight would have been....lol
Old 10-08-2014, 03:56 PM   #25
silversink
silversink's Avatar
My grandfather sent me to look for one of those 35 years ago-----he said don't come back till you find one. I guess I can finally go home----you guys are great
Hotrods don't have valve covers
silversink is offline   Reply With Quote
Old 10-08-2014, 04:04 PM   #26
MikeK
MikeK's Avatar
Mike V. you're absolutely correct. My favorite auto parts supplier carries them as a featured item:
Mechanical engineering 101: If you put an adjustment knob, screw, bolt, or tolerance specs on something, some people will immediately fiddle with it. If you mark it DO NOT TOUCH everyone will mess with it.
MikeK is offline   Reply With Quote
Old 10-08-2014, 04:31 PM   #27
Brentwood Bob
Pinchy the Great: Hope you got some help here. The angle of the inlet side of the muffler pipe into the muffler is important to get the muffler to hang correctly by the hanger on the frame above the rear axle. If you don't have a go-to muffler guy, I would suggest replacement. The Aries muffler is the best choice. It is available direct from Aries, or thru the model a parts suppliers. Built to original specs, and sounds like the original also.
I have had to take a ball pean hammer to the cheap reproductions from the swap meets in order to improve the fitup to the exhaust manifold.
Use a floor jack under the muffler assembly after hooking up the rear mount loosely to the frame as mentioned above.
The floor jack frees up your hands so you can do this job yourself and concentrate on the muffler clamp. I use a small ball peen to tap the clam-shell as I fit it up and alternately tighten the brass nutted clamp bolts snug.
Bob, AKA Pinchy fume.
Brentwood Bob is offline   Reply With Quote
Thread Tools
Display Modes
