Old 05-18-2013, 04:03 PM   #21
Pat Martone
Pat Martone's Avatar
Default Re: How many "leaves" should be in the rear spring?
1931 Flamingo,
Thanks for your good points.
I have never felt my car bottom-out, and I have only had passengers for very short rides. My car does seems to ride good.
Perhaps my tires might not be as "tall" as those cars running normal bias ply tires.
I am using Coker's Excelsior 19" radials (500R19) on my stock (but new) wheels. (The radials handle great compared to bias ply tires.) The radials "squat" a bit, with a larger contact patch on the ground (better for braking); several people have come up to me and said my tires are low on air, but I explain that they are radials and that's why they don't look fully-inflated like the bias ply tires.
Pat Martone is offline   Reply With Quote
Old 05-18-2013, 04:50 PM   #22
1931 flamingo
1931 flamingo's Avatar
The radials just might be your "problem". I'd look for something else to worry about.
Paul in CT
Old 05-18-2013, 08:51 PM   #23
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, the radials will lower it.
Have you dropped the spring out of the frame to check for broken leaves?
Old 05-18-2013, 11:01 PM   #24
Rock Hornbuckle
Rock Hornbuckle's Avatar
[QUOTE=Tom Wesenberg;654116]Yep, the radials will lower it.
Have you dropped the spring out of the frame to check for broken leaves?QUOTE]
Good point Tom, I found three cracked leaves on my front set, that would have broken any time soon.
'29 Standard coupe 45-A / whitewalls
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'55 Ford F-100 / 302
'66 1/2 Dodge Charger
'12 SRT8 Challenger Yellow Jacket Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Thread Tools
Display Modes
