Old 05-16-2013, 07:12 AM   #1
Bill Goddard
Bill Goddard's Avatar
Default Sudden stop shock load
Can someone tell me how to calculate the shock load in lbs of a sudden stop from 60 mph? Or maybe the G - load? I am trying to design a seat belt anchor system. Thanks Bill G
Bill Goddard is offline   Reply With Quote
Old 05-16-2013, 07:40 AM   #2
Sparky
Sparky's Avatar
Default Re: Sudden stop shock load
Acceleration is change in velocity divided by time. How fast are you stopping?
Sparky is offline   Reply With Quote
Old 05-16-2013, 08:55 AM   #3
Bill Goddard
Assume worst case against a wall. Bill G
Old 05-16-2013, 09:34 AM   #4
Sparky
Sparky's Avatar
It's difficult to give an accurate answer without knowing the crash characteristics of the Model A, but I can show you how the calculation is done:
Assume a deceleration time of 0.5 second from 60 mph to zero. THIS IS A BIG ASSUMPTION!
60 mph = 5280 ft/min = 88 ft/sec, so deceleration = 88ft/sec / 0.5 sec = 176 ft/sec^2
Assume a 180 pound person ( mass of 5.6 slugs);
F=MA =5.6*176 = 984 pounds. This is the force on the seat belt; you can divide by two for the force on each attachment point.
Old 05-16-2013, 09:53 AM   #5
MikeK
MikeK's Avatar
@60mph you will not need belts, just an undertaker. If you do not have a shoulder harness the steering wheel will likely kill you at 20mph.
I have belts and shoulder harnesses in my 160B, but I realize they really only help in low speed events. Above 20mph all bets are off.
I used the anchor plates available from the belt companies. Yes, you could rip them through the body, but that amount of force would probably cut me in half with the belt anyway.
Mechanical engineering 101: If you put an adjustment knob, screw, bolt, or tolerance specs on something, some people will immediately fiddle with it. If you mark it DO NOT TOUCH everyone will mess with it.
MikeK is offline   Reply With Quote
Old 05-16-2013, 10:13 AM   #6
CarlG
CarlG's Avatar
Maybe some of the folks from "Down-Under" will respond. From what I understand, seat belts are required and the attachment points have to be properly engineered and subsequently inspected so as to meet specs.
For my own use, I'm pretty much in line with MikeK in that they are basically there to keep me from sliding out when going around a corner and the door pops open. (And my wife requires one when she rides with me!)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-16-2013, 10:22 AM   #7
Sparky
Sparky's Avatar
Same here. Since I don't have any doors (or windows...or roof...) my seatbelt is there to keep me from bouncing out if I hit a big pothole.
Old 05-16-2013, 11:39 AM   #8
Benson
Benson's Avatar
Restorer magazine May Jun 1993 has a multi-page story of belt install with pictures and measurements. Coupes are mentioned in the text and drawings and a Tudor seat is in one of the pictures.
I installed seat belts in the Coupe in 1963. Attachment was to the body sub-rails in Rumble seat area where your feet are when you ride in the Rumble.
In 1966 this anchor system was tested when I hit the rear of 56 Plymouth at 45 MPH that was stopped in the road.
Belts and sub rails held just fine and did not cut me in half. Only some brusing of my shoulder as it hit the steering wheel.
Benson is offline   Reply With Quote
Old 05-16-2013, 11:52 AM   #9
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Does this help, rear anchor point.. Mike K is correct.. Your belt in a model a is ONLY going to keep you in the car when the doors fly open "IF" your lucky.
here they are secured to the rear.
Mark Maron
Ill., Region MARC & MAFCA
27A's, MARC JSC Member
MARC Dearborn 2019 Meet Chairman
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
msmaron is offline   Reply With Quote
Old 05-16-2013, 04:23 PM   #10
Allanw
Allanw's Avatar
Originally Posted by Sparky View Post
...my seatbelt is there to keep me from bouncing out...
Haha! Mental picture!
Allan
'29 Tudor, Canadian RHD
Whangarei, NZ
"Duct Tape can't fix stupid, but it can MUFFLE the sound"
Allanw is offline   Reply With Quote
Old 05-16-2013, 07:28 PM   #11
Bill Goddard
MikeK, Could you tell me where you bought those shoulder belts? thankx Bill G
Old 05-16-2013, 09:34 PM   #12
MikeK
MikeK's Avatar
Bill, It's a complete three-point retractable inertia lock (ELR) system like in a modern car. The door post mounting for the retractor and upper swivel took some engineering on my part for attachment and strength. They are available from several vendors, many are USA made and assembled, some are cheaper chinese LINK
Old 05-17-2013, 08:01 PM   #13
Bill Goddard
MikeK, Thanks for your help. Bill G
Thread Tools
Display Modes
