Old 05-17-2013, 04:50 PM   #1
TudooR31
TudooR31's Avatar
Default Removing Radiator
Having a wild time removing radiator on my 31. (replacing 4 blade fan with new 2 blade) Thought I would have it boiled out while apart.
Seems it doesn't want to twist enough to clear the radiator tabs between the frame & fender. Would removing the shell and/or thin rubber pads under tabs give it move twisting room? I have the hood, front apron, headlight bar, water pump removed now.
Thanks
TudooR31 is offline   Reply With Quote
Old 05-17-2013, 05:14 PM   #2
700rpm
700rpm's Avatar
Default Re: Removing Radiator
Remove the shell.
Ray Horton, Beaver Chapter, MAFCA, Portland, OR
Old 05-17-2013, 11:36 PM   #3
TudooR31
TudooR31's Avatar
Originally Posted by 700rpm View Post
Remove the shell.
That did it. Thanks 700rpm.
Old 05-18-2013, 04:13 PM   #4
59mgaguy
Word of warning. When you have the shop boil out your radiator do not let then pressure check it. The Model A coolant system is non pressurized. They can blow your core out.
59mgaguy is offline   Reply With Quote
