Old 01-21-2019, 11:21 AM   #21
50droptop
Default Re: Highboy Licence plate bracket
This is the solution Iím planning for my Ď36. A red bulb will be added in place of the clear bulb to use this as a 3rd brake light as well.
File Type: jpg 50D96F24-6D59-4230-893D-C192AB27546B.jpg (40.6 KB, 42 views)
50droptop is offline   Reply With Quote
Old 01-21-2019, 01:30 PM   #22
tubman
tubman's Avatar
I like that, but how's chances of a red lens? Can glass be dyed or colored in some way? Perhaps a replacement plastic lens made? This is assuming that there is a clear lens or opening on the bottom to light the plate.
Old 01-21-2019, 03:09 PM   #23
50droptop
I can get access to the lens,however I am hoping to keep the lens white and use a red bulb to simulate the 3rd brake light. Iíve ordered red bulbs this morning and should have them delivered and installed by the end of the week. This light also does have separate bulbs for the license light. These photos may give you a better idea of the of the light output.
Imagine the last photo with a red bulb rather than the pictured clear bulb.
File Type: jpg 2FACDFA6-6E80-4A93-93E8-D92D48BB8765.jpg (69.9 KB, 26 views)
File Type: jpg E733F5FF-0482-4D68-A28E-D31A773C7073.jpg (47.7 KB, 27 views)
File Type: jpg 94872A06-2A96-4B86-885F-A0F6758950BF.jpg (24.2 KB, 23 views)
Old 01-21-2019, 05:56 PM   #24
tubman
tubman's Avatar
OK, cool.
Old 01-21-2019, 07:31 PM   #25
TomT/Williamsburg
TomT/Williamsburg's Avatar
I like it .....
TomT/Williamsburg is offline   Reply With Quote
Old 01-22-2019, 12:00 AM   #26
rich b
rich b's Avatar
Is their a company name and/or model number on the light? Thanks for the post on your light.
Old 01-22-2019, 07:24 AM   #27
50droptop
Rich,
The light is a Lucas 469 used on early Ď50s Jaguars and many other British cars. There are two versions of the light, one where the mounting bolts exit the rear of the housing and another where they exit the bottom. I chose to use the one where the bolts exit the bottom. It allowed me to fabricate a bracket to mount to the rear of the car and have the light remain horizontal rather than aiming skyward due to the slope on the rear on the 36. You can see from this photo I was able to keep the light pretty close to the body and used the top hole of the spare tire mount to run the wire into the trunk.
File Type: jpg 4156A7B7-274F-4233-869E-D714C93A7F98.jpg (47.9 KB, 11 views)
Old 01-22-2019, 07:37 AM   #28
deuce lover
deuce lover's Avatar
Not exactly the same.Here you go guys on EBAY.He has sold 76 so far
https://www.ebay.com/itm/LUCAS-REVER...OOh:rk:18:pf:0
Old 01-22-2019, 10:44 AM   #29
Pete Fl/Wi
Pete Fl/Wi's Avatar
If we are showing our rear ends. Here is mine.
Pete
Pete Fl/Wi is offline   Reply With Quote
Old 01-22-2019, 02:18 PM   #30
Detonator
Detonator's Avatar
I've always used the license plate lights made by the Prince of Darkness. They're more compact than the Hollywood/Drake/Airstream assemblies and have a nice little rib detail. As far as I know they're not repopped, but these little Lucas units were used on dozens of different British cars over the years. They pop up at swaps and on eBay pretty regularly.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 01-22-2019, 03:13 PM   #31
qmdv
qmdv's Avatar
Bugeye Sprite licence plate light on Ebay
https://www.ebay.com/itm/New-Chrome-...-/152736430216
I have owned two different bugeyes . They are positive ground but that should make no difference. They make them new for guys like us but are into Positive earth tea bager cars
qmdv is offline   Reply With Quote
Old 01-22-2019, 03:14 PM   #32
qmdv
qmdv's Avatar
That looks nice. If I had to do over I would do it that way
Old 01-22-2019, 05:26 PM   #33
Bob/Ohio
Bob/Ohio's Avatar
Here is what I used on my Model A project.
Bob
Bob/Ohio is offline   Reply With Quote
Old 01-23-2019, 01:05 AM   #34
Detonator
Detonator's Avatar
Wow. So would I. Those are beautiful, I've always had to buff up old ratty ones, and soak the rubber in glycerine. Thanks for the source.
Seabright Hot Rods
