Old 01-17-2019, 01:15 PM   #1
Brent
Brent's Avatar
Default 30/31 Coupe Subrail Set-Up Measurements
Hey everyone,
I've been having a heck of a time finding mesurements/dimensions to get my subrails into my coupe.
Can someone pull some measurements off their car? Some info I have found online is vague or plain ol' wrong.
I'm looking for the measurement of the cross channels. I feel like I could get it figured if I had those measurements.
Thanks you all for your time,
Brent
Edit: I'm pretty sure Bert's or Brookville is shooting me some #s.
Tools365.net - talking tools 365 days a year.
Brent is offline   Reply With Quote
Old 01-17-2019, 01:51 PM   #2
Don S
Default Re: 30/31 Coupe Subrail Set-Up Measurements
I have 31 coupe that is available to measure for you if you don't get any results from other sources.
Don S is offline   Reply With Quote
Old 01-18-2019, 08:03 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Exactly what numbers are you looking for, ...and what are your plans (-restoration or rod) because there are many details that will need to be done for those to be corrrect. For example, the ends of the cross sills will need to be altered, and the area where the clinchnuts are installed will need to be dimpled and punched. There are a couple of modifications to the sills around the pillar lock and near the area where the frame crossmember will locate that also need to be done. It is probably more than anyone could ever type here. I don't really have a good answer for you. Sorry.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-28-2019, 08:27 AM   #4
Chopd48pan
Hello All. So did you ever get those dimensions? If so, willing to share?
Chopd48pan is offline   Reply With Quote
