Old 08-01-2018, 09:54 AM   #1
chrs1961815
Default 28 Canadian Roadster questions
I checked the engine serial number on my 28 roadster and it is a canadian built 1931 engine which should not be in the car but that is besides the point. My car was advertised as a 28 Roadster but the wheels are a 1930-31 type and the windshield post has mirrors on the post instead of on the wings. Also, when I bought the car, somebody had a 1930 model a plate holder on it. Is there anyway for me to tell if the car is actually a 28? Frame numbers or body numbers?
chrs1961815 is offline   Reply With Quote
Old 08-01-2018, 10:29 AM   #2
Graham
Graham's Avatar
Default Re: 28 Canadian Roadster questions
My Canadian Roadster has a body number on the sill by the seat frame and just inside the top edge. In my case it starts with a T (Toronto assembly). I don't know of a list of assembly numbers sorted by date, but it may be possible to find a similar one and get an idea.
It was easy to mix and match parts as evidenced by the 30 and 31 parts that have made dating mine tough as well.
Graham is offline   Reply With Quote
Old 08-01-2018, 11:20 AM   #3
chrs1961815
No number near the seat frame that I can find. This is probably a good time to ask what this plate is on the floor in front of the clutch and brake.
Old 08-01-2018, 11:35 AM   #4
Steve Plucker
Steve Plucker's Avatar
If you were to lift it up, you will see just where the battery is located...Therefore it is refered to as the battery inspection plate or something like that.
Pluck
www.plucks329s.org
Walla Walla (WA) Sweet A's since 1993
MARC/MAFCA member since 1978
Ford Model AA Truck Club since 1998
(LIONEL/MTH Toy Train Collector, Orange Crush Soda Collector, Steel Beer Can Collector, Old Gas Pump Collector)
Old 08-01-2018, 11:35 AM   #5
heneste
heneste's Avatar
Access cover for the battery.
heneste is offline   Reply With Quote
Old 08-01-2018, 11:36 AM   #6
springerpete
springerpete's Avatar
That looks like the battery access cover. Allows you to unscrew the cell caps and look at the electrolyte levels. Does your car have Robertson ( Canadian) fastenings or ones with a straight slot in the cockpit ? Also check the scxrews that hold the seat back wooden frame together.
springerpete is offline   Reply With Quote
Old 08-01-2018, 11:40 AM   #7
Steve Plucker
Yes there is...Get the MARC/MAFCA Restoration Guidelines and Judging Standards and you can quickly figure out if you have a 28, 29, 30 or 31 Model A Ford.
I do not think that Canadian built Model A/AA vehicles had frame numbers but could be wrong on that fact.
Pluck
www.plucks329s.org
Old 08-01-2018, 12:19 PM   #8
chrs1961815
Most of the screws are robinson typed. Let me check the seat frame.
Old 08-01-2018, 12:22 PM   #9
chrs1961815
Pluck
Thank you for the helpful information. I went on their website and downloaded some files that are helpful. Still looking for some more input from anybody.
Old 08-01-2018, 12:59 PM   #10
chrs1961815
The seat frame has robertson screws as well.
Old 08-01-2018, 02:31 PM   #11
SGT in Ont.
SGT in Ont.'s Avatar
Pictures of your car would help. Headlight lenses, tail light, rad shell, overall picture etc.
SGT in Ont. is offline   Reply With Quote
Old 08-01-2018, 03:14 PM   #12
chrs1961815
Here are some more pictures. I have replaced a few things already. The car is already restored, not the best restoration, but this car has virtually no rust. Under the dash there is still some original paint, Niagra Blue dark.
Old 08-01-2018, 04:48 PM   #13
Tinbasher
Tinbasher's Avatar
Do you a picture of the tailight? If it's 28 and early 29 it could be a drum style that mounts off of the body. With the "Robertson" Screws that tells you it's a Canadian car. The rad shroud says 28-29. 29 was chrome. The straight flutes in the headlight lenses say 28. Here's a copy of the Canadian Serial numbers.
Hope this helps. I'm working on a Canadian 28 Sport Coupe. And trying to make it right.
Tinbasher is offline   Reply With Quote
Old 08-01-2018, 06:51 PM   #14
barnstuf
From the photo I would say it is a 1928 amateur restoration. Overdone in some areas, lacking in other areas.
barnstuf is offline   Reply With Quote
Old 08-01-2018, 07:57 PM   #15
chrs1961815
Here is some photos of the old tail light.
Old 08-01-2018, 08:00 PM   #16
chrs1961815
What do you mean by overdone in some areas? Thanks for your input.
Old 08-02-2018, 07:13 AM   #17
fundytides
I have a 31 Canadian built Std. Roadster. As mentioned, the main difference is the use of Robertson screws. Luckily, since I did a complete disassembly of mine, Robertson screws are generally available here in Canada at hardware stores and fastener suppliers. The only ones I have been stuck for is the door hinge screws. I have managed to salvage most of the old ones and used socket heads where I need new ones. At a glance you don't notice the difference. There is a difference in bumper clamps and data plates both of which can be obtained from Mike's Afordable and probably others. Mikes also sells the Robertson screw kits for Canadian cars. The other difference that I am still struggling with is that the original paint on my firewall is Ford Maroon which is not listed as a color choice for 1931 Std. Roadsters. I can only assume that different color choices were offered in Canada but can find no documentation to back this up. In spite of the lack of documentation, I am going to finish the car in Ford Maroon when I have it completed.
fundytides is offline   Reply With Quote
Old 08-02-2018, 11:03 AM   #18
chrs1961815
I hope someone will compile some information on the canadian built cars eventually. As I mentioned earlier, mine definetely had Niagra Blue Dark as its original color, as some is still visible on the car.
Old 08-02-2018, 11:54 AM   #19
Bob C
The Restoration Guidelines section F has 39 pages devoted to the
Canadian A's.
Bob
Old 08-02-2018, 12:27 PM   #20
Graham
Graham's Avatar
There is a good Canadian Model A history site - the Canadian model A Ford Foundation.
check cmaff.com
It has lots of the service bulletins, advertising, etc.
