Old 04-13-2018, 02:29 PM   #1
Sea-weed
Default Recommendations For Selling
I have a very nice 1930 Town Sedan that I want to sell. The problem is that it's in my garage and hasn't been started for at least 7 years. Should I try and get it running before I post it up for sale? Or has it sat too long? It does turn over with the crank and I have put MM oil in each cylinder. I pretty much know the drill to get it started just worried that I don't do any damage.
As you well know, it ran when it was parked.
Will try to attach a pic of it.
Thanks, Rich
(located in Cape Cod)
Sea-weed is offline   Reply With Quote
Old 04-13-2018, 02:36 PM   #2
Tacoma Bob
Tacoma Bob's Avatar
Default Re: Recommendations For Selling
Wish you were closer. Just what I have wanted for a long time.
Tacoma Bob is offline   Reply With Quote
Old 04-13-2018, 02:43 PM   #3
Charlie Stephens
If I looked at a car that didn't run I would assume if it was easy to start the seller would have done so. Since the seller didn't get it started I would assume it needs a new engine and price it accordingly.
Charlie Stephens
Old 04-13-2018, 02:43 PM   #4
J Franklin
J Franklin's Avatar
Dump the oil and gasoline and replace with fresh. The battery may need to be replaced. I bet with very little trouble that car will start right up. You may also need to burnish the points as they can get corroded a bit and cause no ignition. It is best to prove to a new prospect that it runs than leave to their imagination all the problems the mind can conjure up.
Old 04-13-2018, 02:50 PM   #5
Sea-weed
Thanks guys. I agree, if I was looking, I'd want it to run. Will go thru the gas, oil, points, etc.
Old 04-13-2018, 07:39 PM   #6
Flathead
Flathead's Avatar
Charlie Stephens
This makes a pretty good point about the situation.
Flathead is offline   Reply With Quote
Old 04-13-2018, 07:43 PM   #7
Step-down
Step-down's Avatar
After you dump oil , pull the dissy and dump oil down the dissy hole into the dip tray , drop dissy back in check timing ....
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 04-13-2018, 08:36 PM   #8
J Franklin
J Franklin's Avatar
I say don't mess with any more than it takes to get it running. See how it is and do more if you need to. Don't touch the timing until you see how it is running!
Old 04-13-2018, 10:52 PM   #9
SeaSlugs
SeaSlugs's Avatar
Charlie Stephens
Same here - i assume the seller knows theres an issue and they arent telling me and I'm going to assume it needs new bearings. Or the trans is out, or rearend is out. Without the engine not running i would assume everything driveline wise is shot and price accordingly. Hard to test the brakes as well so assume theres work to be done there.
Get it running, even half assed to make it down the block. That way at least the buyer knows the brakes, rearend, trans is good and can hear for major engine problems.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-14-2018, 05:31 AM   #10
ronn
real nice looking car!
GL with your sale.
Old 04-14-2018, 06:00 AM   #11
WHN
Car looks great.
Why has it not been driven for seven years?
Good luck with the sale.
Old 04-14-2018, 07:15 AM   #12
Sea-weed
Thanks everyone. I guess I knew the answer before I asked the question. I purchased the car because I love old Fords but it gradually got used less and less as I had other "stuff" to do. Now I need the space or a bigger garage.
Old 04-14-2018, 09:01 AM   #13
CapeCod_28A
CapeCod_28A's Avatar
Nice looking car. I'm a Cape Codder just getting into Model A's.
CapeCod_28A is offline   Reply With Quote
Old 04-14-2018, 10:17 AM   #14
aford193031
aford193031's Avatar
Nice looking car, I would have it running before trying to sell it, as others have said.
aford193031 is offline   Reply With Quote
Old 04-14-2018, 08:28 PM   #15
heneste
heneste's Avatar
Nice car! It will be easier to sell if the engine is in running condition and you'll probably get a better purchase price too. As long as the engine doesn't need major overhauling/expense and it just needs to be refreshed, I would opt for the time to get it going. As Charlie mentions above, some buyers will be leery or scared from purchasing if they feel something's wrong with the engine. If you're worried about missing something to get it going, check with the local clubs to see if anyone would be willing to help out.
heneste is offline   Reply With Quote
Old 04-14-2018, 09:44 PM   #16
Cape Codder
Cape Codder's Avatar
Just wondering where you are on the Cape. I'm over in Bourne.
Cape Codder is offline   Reply With Quote
Old 04-14-2018, 10:43 PM   #17
burner31
burner31's Avatar
Gorgeous, beautiful; very attractive car you have there SEA-WEED.
Thats the paint combo I'm going to have on mine.
Even if it only just starts...you should get a good price...good luck to you Sir
Keith
Shawnee OK
'31 SW 160-B
Old 04-15-2018, 05:47 AM   #18
Hoogah
Hoogah's Avatar
I'd get it running and change the J to a Y on the number plate. Could attract a whole new class of potential buyer - you know, the ones who like to make a statement with their plate!
Seriously, that is one nice looking A! Are you sure you want to sell it?
Hoogah is offline   Reply With Quote
Old 04-15-2018, 06:39 AM   #19
Sea-weed
Hi. I'm in Falmouth.
Old 04-16-2018, 06:19 AM   #20
krzewinskibe
krzewinskibe's Avatar
Go for the bigger garage
1929 Tudor
krzewinskibe is offline   Reply With Quote
