Old 05-09-2013, 05:08 PM   #1
jbc
jbc's Avatar
Default Thermostat -= Yes or No
I just had my radiator rodded out and I plan on replacing both the hoses. my question-should I continue run a thermostat. I have one in my old hose now, but sometimes it over heats on hills? Not many hills here in Florida, but last year in Tennessee, it was a little hilly.
jbc is offline   Reply With Quote
Old 05-09-2013, 05:22 PM   #2
TinCup
TinCup's Avatar
Default Re: Thermostat -= Yes or No
You know here in Oklahoma I run one during the winter months just to help bring the car up to temp. If I don't the car never runs over 140 and sometimes when it is really cold not even that. It causes for unburned condensation to build up. I can't see where you would need one in FL.
Sooner Model A Club of Oklahoma
TinCup is offline   Reply With Quote
Old 05-09-2013, 05:31 PM   #3
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
yes
Mark Maron
Ill., Region MARC & MAFCA
27A's, MARC JSC Member
MARC Dearborn 2019 Meet Chairman
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
msmaron is offline   Reply With Quote
Old 05-09-2013, 05:40 PM   #4
tudoor
yes
tudoor is offline   Reply With Quote
Old 05-09-2013, 05:41 PM   #5
1931 flamingo
1931 flamingo's Avatar
There must have been a reason you had it rodded out, yes? Overheating? The t/stat, unless stuck had nothing to do with the overheating, as the others have said, re-install it. JMO
Paul in CT
Old 05-09-2013, 05:54 PM   #6
Mitch//pa
yes
Old 05-09-2013, 06:03 PM   #7
steve s
steve s's Avatar
yes
steve s is offline   Reply With Quote
Old 05-09-2013, 06:04 PM   #8
green30coupe
green30coupe's Avatar
Yes (40 miles from Ocala)
Ed
LAW OF MECHANICAL REPAIR
ONCE YOUR HANDS BECOME COVERED WITH GREASE,
YOUR NOSE WILL ITCH AND YOU'LL HAVE TO PEE
green30coupe is offline   Reply With Quote
Old 05-09-2013, 06:18 PM   #9
ctlikon0712
ctlikon0712's Avatar
Yes, Cocoa, Fl. You don't need one but the engine runs better with it.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 05-09-2013, 10:07 PM   #10
Special Coupe Frank
Special Coupe Frank's Avatar
And the engine will last longer with one...
Packard and Cadillac started using them in 1915-16.
Special Coupe Frank is offline   Reply With Quote
Old 05-09-2013, 07:20 PM   #11
160B
160B's Avatar
Yes!!!
A thermostat allows the engine to heat up to operating temperature faster, and keeps the engine at a more constant temperature!!
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 05-09-2013, 07:30 PM   #12
jbc
jbc's Avatar
Thanks everyone, I'll put in a new one.
Old 05-09-2013, 08:03 PM   #13
steve s
steve s's Avatar
Make sure that it has a 1/8 inch bypass hole drilled in the flange, so there is enough flow to allow the stat to sense the coolant temp and to prevent localized hot spotting in the head during warmup.
Some of us drill two bypass holes, just to be sure. Slows warmup somewhat but if you've ever seen explosive vaporization, you won't mind.
Steve
Old 05-10-2013, 12:02 AM   #14
Jordan
Jordan's Avatar
Steve
Some of us drill 3
Cowtown A's
Jordan is offline   Reply With Quote
Old 05-09-2013, 08:07 PM   #15
whirnot
whirnot's Avatar
I'm not real experienced in Model A's but am in industrial ventilation. If you take that stone guard off in front of the radiator I bet it won't overheat anymore. Yes air does go through it, but just imagine moving all the wires in that stone guard to the center, and see how much surface you have blocked.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 05-10-2013, 12:48 PM   #16
roccaas
roccaas's Avatar
I ran one in my Cabriolet one Winter, and it was great on drive ability and warm up.
The first hot South Georgia day, the temp gauge rose alarmingly, so I pulled it out, no more problems. Mine does have the bypass hole, and perhaps it didn't open correctly, but in this heat and humidity (and Stone Guard) I'd rather rely on more water flowing unimpeded.
With Global Warming, I doubt I'll ever put it back in.
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
