Old 01-10-2020, 05:28 PM   #1
Dewshan
Default Front motor mount fixed!
I ended up taking the pulley off to get access to the problem springs. It was a bumper clamp backing plate! Everything is back together now. This is going to be an interesting project! https://imgur.com/a/r7CC89g
Dewshan is offline   Reply With Quote
Old 01-10-2020, 08:34 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Front motor mount fixed!
Nice job! Looks very good nice set of wheels too
www.whidbeymodelaclub.com
Old 01-11-2020, 11:08 AM   #3
aford193031
aford193031's Avatar
Good that you got the mount fixed. Nice looking Vicky!
aford193031 is offline   Reply With Quote
Old 01-12-2020, 08:50 PM   #4
Synchro909
Synchro909's Avatar
How the heck do you stop those front engine mounts squeaking where they go through the cross member? I have 2 cars where that happens but only while I don't have my foot on the clutch. I suspect Flota Motor engine mounts contribute to it.
Old 01-13-2020, 01:15 AM   #5
RandyinUtah
Synchro to stop the squeaking open up the center hole a little bit for clearance and put a little grease around the hole.
The Service manual shows a change in this flat spring.
RandyinUtah is offline   Reply With Quote
Old 01-13-2020, 08:32 AM   #6
rocket1
I used a brass kitchen faucet threaded adaptor,it fit in the cross member hole and the shaft on the front mount passed through it,worked.
rocket1 is offline   Reply With Quote
