Old 01-20-2014, 12:35 PM   #1
stouchton
stouchton's Avatar
Default How well to repro splash panels fit?
Hi Folks,
31 Roadster with surface rust under the paint on the splash panels. Trying to decide if it is worthwhile to remove them and refinish them -or- simply buy replacements, prep and paint.
Currently everything fits together beautifully - not sure if repro splash panels are shaped correctly. Anyone have any experience with them?
Thanks
stouchton is offline   Reply With Quote
Old 01-20-2014, 12:39 PM   #2
perichbrothers
Default Re: How well to repro splash panels fit?
I just installed a set of repop panels and running boards on a 30 coupe and was surprised how well they fit. These were an early batch though have no idea the manufacturer.
TP
perichbrothers is offline   Reply With Quote
Old 01-20-2014, 12:51 PM   #3
700rpm
700rpm's Avatar
I got one from Sacramento Vintage and it fit perfectly, but I agree with Charlie Stephens (below).
Ray Horton, Portland, OR
Old 01-20-2014, 12:55 PM   #4
Charlie Stephens
As a general rule it is better to refinish the original parts. If they are in good shape this would be an excellent place to use powder coating.
Charlie Stephens
Old 01-20-2014, 12:58 PM   #5
juke joint johnny
juke joint johnny's Avatar
The ones you have Fit !!! Why tempt fate buying new ones!!!
juke joint johnny is offline   Reply With Quote
Old 01-20-2014, 03:26 PM   #6
FirstA
FirstA's Avatar
I installed a set of splash guards and running boards from Howells. The splash guards were ok but the running boards mating to stock fenders was not good. Original parts were not available to me so I had no choice.
FirstA is offline   Reply With Quote
Old 01-20-2014, 04:56 PM   #7
stouchton
stouchton's Avatar
Thanks guys - appreciate the feedback.
I was concerned about tempting fate with the fit. And I never even thought about powder coating them!
I am going to pull them off and try to salvage them first. Hoping the surface rust under the paint does not go too deep.
Old 01-20-2014, 05:32 PM   #8
pooch
pooch's Avatar
Definitely use the original.
Check them over, if OK, find a good sandblaster and paint to match.
I doubt you will be happy with powder coat on a body panel.
pooch is offline   Reply With Quote
Old 01-20-2014, 06:34 PM   #9
ericr
ericr's Avatar
I bought the more expensive repros from Snyder's that have the original-design offset on the rear tail and they fit better than the 1980s version I was replacing. It would be nice to compare the originals to repros as I wonder if the curve on the originals was a better-fitting die-stamping and whether repros are simply bent on a brake.
ericr is offline   Reply With Quote
Thread Tools
Display Modes
