09-18-2019, 07:19 PM | #21 |
Re: 292 y-block distributor puzzler
Ummm, hate to tell you this, but the reason you are experiencing slipping of that linkage is because you are missing a tension spring between the upper and lower sprags of that kickdown element.
The reason they have that slot in there is so you can punch the gas pedal and achieve intermediate gear kickdown without damaging carburetor butterfly valve shaft and associated linkage. That spring takes up the slack, but during normal driving the spring holds that kickdown element steady. I suggest NOT using your passing gear kickdown until you can replace that missing spring and pull that piece of plastic tubing out of there. Once that spring is put back, you should be good as new. |
09-18-2019, 07:25 PM | #22 |
Here is a photo of '55 Ford Y-block with 2-bbl carb passing gear link. Notice the two movable plates with the spring pulling them together. That is the spring you are missing. The slot on mine is hidden on the backside.
09-18-2019, 07:28 PM | #23 |
I was just about to look in the '56 parts book to check on that area. A missing spring (just broke and fell off most likely) would explain the problem. I put the hose piece there just to test my theory. I've been collecting and working on "older cars" for 40 years and this was one of the harder problems to figure out, even though it's simple in a way.
Bill |
09-18-2019, 08:26 PM | #24 |
"And de-acceleration."
The dual diaphragm '56 only momentarily retards the spark in low manifold vacuum when accelerating. Deceleration is high vacuum. The text in the link I posted earlier explains how it all works. Sal |
09-18-2019, 08:28 PM | #25 | |
I had a similar problem with my 56 TBird. I put and extra spring on it and it now works fine.
09-19-2019, 12:47 AM | #26 |
***** - DISCLAIMER -
The above posted information is in my opinion only (IMO) and may contain copy and paste material(s). In addition, any above tech information is supplied in good faith. No responsibility implied or otherwise can be accepted for the way others use or interpret provided data. Your experience(s), opinion(s) and mileage may vary. DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
09-19-2019, 10:49 AM | #27 |
I believe that info was from Holley or Ford, and I believe it to be true from my experience. To each his own.
Sal |
09-19-2019, 06:06 PM | #28 |
I have no idea. The referring URL you posted expired. You cannot post a SEARCH URL as it will self destruct. Remember MISSION IMPOSSIBLE?
09-19-2019, 06:19 PM | #29 |
I guess I don't know computers that well. When I click on the link it says it's expired, but shows a link to go to it anyway. I've tried it twice and worked both times for me. If you can't see it, maybe just google "1956 Ford dual diaphragm distributor". That's how I found it originally.
Sal |
09-19-2019, 08:25 PM | #30 |
probably not helpful to have that hose laying on top of the bellcrank mechanism. I would reroute it. Just to take that out of the equation.
Good luck with the issues, These vac advance deals with the 56 Load a matic are frustrating but can be solved with a lot of patience. And unfortunately some extra money sometimes. Hang in there. |
09-19-2019, 08:32 PM | #31 |
The fuel hose is a problem. If you route it under the bellcrank mechanism, it is getting pinched against the intake manifoold. How did the factory do it?
09-19-2019, 09:14 PM | #32 | |
It is not supposed to be rubber hose at all. It should be metal tubing. Try to duplicate the routing shown in the '56 Ford car shop manual in various places, or you can actually buy that fuel inlet tubing (pre-bent) from various repro parts suppliers. I got all my undercar fuel and brake line tubing from a company called "Inline Tube", but they also carry a complete line of fuel and vacuum tubing for the engines. The rule of thumb I like is: Use as LITTLE of rubber tubing as possible in fuel and vacuum systems. Rubber breaks down under heat and age and becomes damaged by contaminants in ethanol, so it needs to be checked for cracks periodically. Metal tubing lasts practically forever. Some of your chain auto-parts stores have been offering copper-alloy tubing for a while now, so if you are creative like me, get some and bend your own for custom fit. And get new brass compression fittings too. |
09-21-2019, 05:39 AM | #33 | |
Just wondering ~ has the problem been found with the spark retarding (with vacuum connected ) at idle?? |
09-21-2019, 07:31 AM | #34 |
Stiggy - no. None of the reference manuals say anything about the correct vacuum readings except the reading of 6 degrees BTDC with vacuum advance shut off. But the ATDC reading may be correct anyway. In a regular system, when you check timing at idle, there may still be a small advance contributed by the centrifugal advance weights in the distributor. I’m not sure about that. There’s no obvious way to check timing under true load conditions Where manifold and ported vacuum change as soon as the engine is put under load. I’d like for others to report their vacuum reading at idle with the vacuum lines connected. I still could have a faulty unit though it seems to work ok.
09-21-2019, 09:34 AM | #35 |
Look in your SHOP MANUAL under SPECIFICATIONS and you should find the advance specs there.
09-21-2019, 09:51 AM | #36 |
It shows the base reading of 6 degrees BTDC for no vacuum to the advance unit. I can’t find a reference anywhere on readings for other conditions. This was a one or two year item that depended on the teapot with the spark control valve. In 1957 the whole system was dropped.
09-21-2019, 12:57 PM | #37 | |
You went to the SPECIFICATIONS SECTION of the FORD 1956 SHOP MANUAL and under IGNITION did not find the curving and vacuum values? I understand the LOAD-O-MATIC SYSTEM, so no need to post the description. BTW - LOAD-O-MATIC was used on six cylinders until the 1968 model run.
09-21-2019, 02:24 PM | #38 |
Even if you have the specs on how much vacuum to the distributor inner diaphragm, and how much spark advance that vacuum level represents, I don't think you will be able to check it with a timing light unless you have the engine on a dyno, or the car on a chassis dyno since all the specs are based on light to heavy loads on the engine and not racing the engine in neutral. I can tell you based on my Holley carb manual that the most vacuum you will see is about 4" hg. And that is at high RPM and basicly wide open throttle. At that point the vacuum signal is mostly from venturi vacuum (suction)and not manifold vacuum. Manifold vacuum at wide open throttle will be no more than 2" hg at high RPM.
Sal |
09-21-2019, 03:24 PM | #39 |
Not to over-ride you Sal, but actually the values in the SHOP MANUAL are intended to be used on a DIST ANALYZER.
The complete system (DIST and CARB) is so complex, I don't see how anyone (without wild guessing) could calibrate one on the car as you can a DUAL ADVANCE. You might get it somewhere operational but not to spec. The ONLY USE I can see to use the LOM if the car is a dedicated restoration. Even then (if a driver) I would have the two systems on hand if I wanted to drive it. But the values are in the MANUAL.
09-21-2019, 06:02 PM | #40 |
I agree that loadomatics are probably all over the place as far as two working the same.
The specs I have are from Holley for their distributor, but they give the specs for the '56 Teapot carb vacuum, and are all based on distributor RPM versus engine load (manifold vacuum). If it were my car, I would probably have an aftermarket or '57/later Ford distributor on it. Sal |
Thread Tools | |
Display Modes | |
