Old 07-20-2019, 01:53 PM   #1
Tom Z...
Default 35 Ford cpe running boards
Does anybody know where I could get a pair of 35 Ford cpe running boards? Drake, Mac, Carpenter etc. out of stock. Bare stock type repro ok. Thanks Tom
Tom Z... is offline   Reply With Quote
Old 07-21-2019, 01:39 AM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: 35 Ford cpe running boards
Beware,
Most non rubber covered repro board are not formed correctly and are straight from the front to the back. There should be a shallow arch front to back matching the line of the bottom of the body.
In addition a board designed to be smooth and painted will be oversized to add the thickness of the rubber to the exterior of the board... A rubber cover will not fit one of these.
Drake is the manufacturer of the rubber covered boards, and they are quite nice. They have also indicated they are committed to making additional runs from time to time. Your best course is to be patient and prepared to pay the big$$$.
If you are going to do a smooth, painted board then fiberglass should be an option. Note the key concerns of the proper arch and proper oversize.
Karl Wescott is offline   Reply With Quote
Old 07-21-2019, 06:43 AM   #3
deuce lover
deuce lover's Avatar
Another option is to recover the originals
deuce lover is offline   Reply With Quote
Old 07-21-2019, 08:01 AM   #4
DavidG
DavidG's Avatar
There used to be a fellow in Georgia (?) who recovered '35-'36 running boards (among others) and perhaps still does. While I wasn't a customer, I understand that the results were outstanding. Someone herein will likely recall his name and contact information.
P.S. The boards of a '35 coupe are the same as all the rest of those on '35-'36 North American-built passenger cars.
Old 07-21-2019, 09:01 AM   #5
TJ
TJ's Avatar
Dave, the guy in Georgia was Hunley Acuff. I believe he closed down his business.
Old 07-21-2019, 09:01 AM   #6
deuce lover
David.That man is Huntley Acuff.Had him do a set in 2004 for me.Don't think he is around or doing anymore.I told Tom Z about a set I know of.
Old 07-21-2019, 09:04 AM   #7
TJ
TJ's Avatar
Did you call C and G Parts, or All Ford Parts in Campbell, Ca.? Call as many vendors as you can find as someone may have a pair in stock
Old 07-25-2019, 08:27 AM   #8
Tom Z...
Thank you guys for the info on the 35 F running boards. Thats the problem I do not have the originals to get them recovered. I will try other vendors. Tom
Old 07-25-2019, 09:38 AM   #9
V8ER
Where are you located? I have one original running board.
V8ER is offline   Reply With Quote
Old 07-25-2019, 11:12 AM   #10
Tom Z...
The reason I need the running boards Drake $285, Mac $285 plain stock, not the covered ones $1200 it will make my 35 F 3w cpe complete and I have to put the body back on and finish a few other things and then it goes up for sale. V8ER, thanks for your reply I wish you had the pair. I live 1hr north of Hershey in NE Pa. Thanks Tom
Old 07-25-2019, 11:37 AM   #11
flathead34
flathead34's Avatar
Tom, I have the boards. A pair of original bare Ford boards in excellent condition ($250.) and my son has a pair of new Drake boards ($1000.) Check you PM's. Mike
flathead34 is offline   Reply With Quote
Old 07-25-2019, 11:47 AM   #12
deuce lover
Whatever you do - do not buy the repop plain steel.Bob Drake even told me they do not fit.
Old 07-26-2019, 12:20 PM   #13
Tom Z...
flathead34, I sent a return PM with my info, I hope I did it right. I am interested in the boards. Tom
Old 07-27-2019, 12:46 PM   #14
flathead34
flathead34's Avatar
Tom, Send me your email. The PM's do not seem to be working for us. Mike (flathead34)
Old 08-09-2019, 10:25 AM   #15
TJ
TJ's Avatar
The '35 Galaxy is probably a mate to his 1935 Ford Comet.
Old 08-09-2019, 10:26 AM   #16
Fordestes
35 ford Galaxy ? Learn something new everyday.
Fordestes is offline   Reply With Quote
Old 08-09-2019, 10:29 AM   #17
tubman
tubman's Avatar
I thought scammers only frequented the "Swap Meet"; looks like they are migrating to the discussion board.
Old 08-09-2019, 11:06 AM   #18
TJ
TJ's Avatar
I think Ryan must have pulled his initial post and any posts to other threads.
Thread Tools
Display Modes
