08-29-2018, 11:42 PM | #1 |
42- 2dr sedan chassis
Hi all my first post, I have a 42 2-dr I imported from Tennessee a few years ago and NZ compliance requires proof way chassis was built before can put on road it is a stock standard chassis with what looks like the center x-member is a welded box where the four inner legs mate to it, it is not the raised type but more the 41 pancake type, I have a copy of Van-Pelts 42 chassis showing what looks like vert lines where mine has welding both butt and angle, read that this chassis due to war was only built for short time before they bought out the 46 type, anyone have documents or closeup photo as sure seen a photo once that looked like it had the welds as well,cheers
08-30-2018, 07:46 AM | #2 |
Re: 42- 2dr sedan chassis
Can you post a photo or two of yours? DD
08-30-2018, 01:36 PM | #3 |
Hi v8coopman,will be a couple of weeks before can get photo as I live winters in Australia and cars in NZ, when I'm going back to NZ was hoping to get it finally passed but as only had 20 working days before having to pay another $450 for compliance trying to get the proof of another 42 chassis built the same way first, cheers Bob
08-30-2018, 03:09 PM | #4 |
Interesting, but not sure I am totally understanding this. How would the authorities have any idea how the frame was built? Wouldn't the serial number stamped into the frame be the deciding factor?
08-30-2018, 03:30 PM | #5 |
Hi Jseery all cars now imported into NZ must have a compliance check and any that may have rust or signs of any damage or fresh paint none of which mine shows except for drip rail repair on roof done when ? who knows may have been 40 yrs ago must then have a certifying repair engineer inspect and his charge another $350 and has to go up on a hoist wherever I can get access so he can walk under it so he can decide if acceptable or not and any further repairs or reinstatement to original specs and u only are given 20 working days to comply or a recharge of full amount in my case $460 cheers, Bob Ford
08-30-2018, 03:39 PM | #6 |
08-30-2018, 04:10 PM | #7 |
RJ, have you asked member 'meric42'? He is a kiwi with a 42 or two....
08-30-2018, 04:20 PM | #8 |
Hi Brian yes have made contact with Meric he suggested me posting on here, cheers Bob
08-30-2018, 04:21 PM | #9 |
Sounds like a money making scheme to me!$$$$
08-30-2018, 04:22 PM | #10 |
Very interesting process, thanks for the explanation.
08-31-2018, 01:53 AM | #11 |
I have a 42-48 chassis but it is riveted not welded and believe it or not I live in Tennessee.
08-31-2018, 03:55 AM | #12 |
Hi Marvin it came from Ron Watson in Athens I have seen pictures of some with the rivet's but the four legs or extensions where they meet the x in the center on mine have both vertical and angle butt weld's not one piece like early or later ones which run full length but with a curve
09-11-2018, 03:46 PM | #13 |
Hi all found this on eBay motors item no 223123870496,looks like what I have been trying to confirm with my 42 2-dr chassis, picture no seven seems to show a fully welded box in the center, x-member makeup with the four legs then welded to it. this ones in Fullerton, Ca.
09-11-2018, 04:01 PM | #14 |
Assume this is what you are referring to. https://www.ebay.com/itm/1942-1946-1...MAAOSw~Q9bR-kr
09-11-2018, 04:23 PM | #15 |
Hi Jseery, thanks for posting yes but pic no seven shows a even closer look at center showing the welding and of cause no MiG welding then,seems that's part of the proof I need now just need to convince the certifier, maybe only a few built this way was starting to think mine may have been a prototype, going to NZ next week ,cheers, Bob
09-11-2018, 04:28 PM | #16 |
Does this help any? I cropped the first one and brightened the second one.
09-11-2018, 04:31 PM | #17 |
Hi Bob,
If this is what you are talking about then it is the same as the chassis under my Sedan Delivery? I can photograph that tonight and send you a picture of it tomorrow if that will help?
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
09-11-2018, 04:39 PM | #18 |
Great shot sir I apricate the help in showing pic, myself at 73yrs young couldn't figure out how too, seems the butt welding caused the inspector to comment they believe mine may have been cut in half,wonder if there are many more built that way as later ones seem to have a riveted top on ,again thanks
09-11-2018, 04:48 PM | #19 |
Hi Meric, yes would love a photo of one in NZ to add too this one also when dust has hopefully settled and compliance done and the customs time frame for selling allows me to sell which I think off hand was set at 14 months then in the far north of NZ will be a 2-dr looking for a new owner, cheers Bob
09-11-2018, 07:27 PM | #20 |
I don't know what years, but in the 42-48 years some center sections of frames were riveted in and some welded. I have seen both. Mine is riveted (48). May have depended on where the frames were built??
