Old 04-14-2018, 10:43 AM   #1
1930artdeco
1930artdeco's Avatar
Default spark plug cleaning
Hi All,
Slightly off topic here-sort of. I wan in an antique store yesterday and found one of the hand held spark plug cleaners , the one with the bag of sand on top. Well I got to wondering if it would work on our plugs, but the rubber hole where you stick the plug seemed two small. Will it fit, could I make it bigger, or do these not work at all?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-14-2018, 11:06 AM   #2
California Travieso
Send a message via Yahoo to California Travieso
Default Re: spark plug cleaning
Mike,
I can't answer your question but I remember most of the gas stations had those dedicated spark plug cleaners back in the day when all the gas stations did lube, oil changes and tune ups.
A spark plug cleaner would be a nice addition to a personal garage. Hope you bought it.
David Serrano
California Travieso is offline   Reply With Quote
Old 04-14-2018, 02:11 PM   #3
Flathead
Flathead's Avatar
Doesn't the bag of abrasive go on the bottom and the plug fits into the top?
Flathead is offline   Reply With Quote
Old 04-14-2018, 02:47 PM   #4
marty in Ohio
marty in Ohio's Avatar
Flathead's right. The sand bag goes on the bottom. I found one of those cleaners a few years ago and I gave it to a model A friend. We just reamed the hole in the rubber opening a little bigger. Works good!
Marty
marty in Ohio is offline   Reply With Quote
Old 04-14-2018, 02:59 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
I have had one of those for years but i have seen them recently at Harbor Freight.
Old 04-14-2018, 04:23 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
They're a GREAT sand blaster, for small parts or when you can't get yo' SKILLET CLEAN!
Bill Owncook
"THE ASSISTANT GURU OF STUFF"
Old 04-14-2018, 06:38 PM   #7
Fullraceflathead
Fullraceflathead's Avatar
I actually collect the larger Spark Plug Cleaners and Testers from Years ago.
If you Clean your Spark Plugs make SURE there is no Sand wedged in between the Porcelain and the metal Shell.
If you see Sand inside there poke it loose with a wire or round gapping tool until its gone.
Air Blast then file and re gap and your all set.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 04-14-2018, 08:47 PM   #8
Gary WA
Gary WA's Avatar
Make hole bigger I use glass bead ! Work great.
www.whidbeymodelaclub.com
Old 04-15-2018, 07:47 AM   #9
daren007
They came with different rubber adapters for different size spark plugs. Buy the correct abrasive.
daren007 is offline   Reply With Quote
Old 04-15-2018, 08:27 AM   #10
Merc Cruzer
Merc Cruzer's Avatar
For those of us that are more visually oriented:
Merc Cruzer is offline   Reply With Quote
Old 04-15-2018, 10:45 AM   #11
BILL WILLIAMSON
Mines' orfice hole was worn & I could even use SAND BOX, sand, after running it through a Flour Sifter.
Bill Makeshift
Old 04-15-2018, 04:23 PM   #12
Keith True
Keith True's Avatar
I have one of those nailed to the door jamb in my garage.There are a couple of different rubbers on a nail next to it,and a couple pieces of piano wire to poke in the plug after you're done blasting.I think the rubbers are something I carved out of old shock rubbers.I also have an old Autolite wall mounted cleaner and tester.It is about a foot tall,and has a chrome lever on the side to run it.It kind of looks like the old Southwind gas heater in my 39 Ford pickup.
Keith True is offline   Reply With Quote
Old 04-15-2018, 05:02 PM   #13
noboD
I can remember reading several experts saying sand blasting causes a rough surface on the porcelain which causes more carbon to stick. Besides when the electrodes are worn the plugs need to be thrown away.
noboD is offline   Reply With Quote
Old 04-15-2018, 05:26 PM   #14
BILL WILLIAMSON
REMEMBER, if your car runs PRIMO, don't even look at the plugs, you want to wear out the THREADS?
Bill Zoom
Old 04-28-2018, 07:39 PM   #15
1930artdeco
Well I went back and got it. It is a VIXEN brand spark plug cleaner. Hooked it up and it works. Now I just need to clean it out and find the right media.
Mike
1957 Country Sedan
Old 04-28-2018, 08:18 PM   #16
oldforder
oldforder's Avatar
I have always been told that if you use one of those to bed SURE to clean the plug of all the grit. If it gets stuck up around the porcelain way up high, and falls out in the engine it plays heck with the rings. Or so I have been told.
oldforder is offline   Reply With Quote
Old 04-28-2018, 08:55 PM   #17
1930artdeco
Makes sense to me. I am using 3X plugs so I can take them apart to clean all the grit out.
Mike
1957 Country Sedan
Old 04-29-2018, 08:48 AM   #18
katy
katy's Avatar
I have one of those, looks like Merc Cruzer's pictures.
Been sitting on the back of the bench for years.
It never worked sitting on the bench, now after reading this thread and doing a bit of web research methinks it should be mounted vertically.
Gonna find a place to wall mount it and give it a try.
Might need to find new grit for it.
Old 04-29-2018, 04:46 PM   #19
redmodelt
redmodelt's Avatar
The only problem with taking plugs apart is getting them to reseal after. The crush rings can be found that might work but are not an off the shelf item anymore.
Old 04-30-2018, 07:53 AM   #20
Dave Dta
I remember using one of those Vixen plug cleaners, and I believe the media was called Crisolite or something like that, available from the local auto parts store. Dave
Dave Dta is offline   Reply With Quote
