Old 09-01-2019, 01:40 PM   #1
Gwill65074
Gwill65074's Avatar
Default Cylinder head marking
My head has a diamond logo or marking between the 3 and 4 cylinders, what the heck does this mean?
Thanks
Gwill65074 is offline   Reply With Quote
Old 09-01-2019, 01:48 PM   #2
Railcarmover
Default Re: Cylinder head marking
Castings were made under contract by different foundries after model a production ended.A number of different foundry marks have been identified,the 'diamond' mark is highly prized with engine blocks.Are there any other markings? Ford script is another indicator of a service head (heads produced for service after 1931) .The one in the picture shows a 1936 service head I have..its a high quality casting,clearly better than a production head. The L286 casting mark above the water pump boss indicates it was cast 12/28/36
Railcarmover is offline   Reply With Quote
Old 09-01-2019, 02:18 PM   #3
Gwill65074
Gwill65074's Avatar
On one of my heads there is a Ford script around cyl 3 and at the water pump there is B117. On the other head, I took a picture of the triangle above cly 3 but I don't know how to post it here.
Old 09-01-2019, 03:19 PM   #4
Railcarmover
B117
B = month of casting
11 = 11th day of month
7 = year of casting,presumably the 30's,so 1937
there were a number of foundaries casting for ford,all kinds of marks,triangle,diamond MHC and an assortment of others.I bet that B117 head appears to be a nice one.
Old 09-01-2019, 04:24 PM   #5
Gwill65074
Gwill65074's Avatar
Yes it is, really clean
Old 09-01-2019, 05:37 PM   #6
Railcarmover
Diamond marked B blocks are the holy grail,the diamond is right above the timing gear inspection cover..If you come across an A or B block with it,grab it..
Old 09-01-2019, 06:18 PM   #7
Gwill65074
Gwill65074's Avatar
I've got a fresh one sitting in the garage, it came off a Gleaner, it's a 1937 Rouge production.
Old 09-01-2019, 08:09 PM   #8
Railcarmover
You get hankering a build for speed that's the one..
Old 09-03-2019, 10:08 AM   #9
katy
katy's Avatar
The number on the top front of the (used) head that I just installed reads 92447. Would that be September 24 1947?
Don't go away mad, just go away.
