Old 03-12-2018, 07:36 PM   #1
kimeccles
Default running board rubber glue?
I have the new running board pyramid rubber mid-1930 Cabriolet that comes with a white paper covering adhesive backing that is peeled off to stick them on.
Is this good enough, or should I use some additional weatherstrip adhesive to hold it down before I start to install the zinc strips that hold down the edges?
engine/frame # mid-May1930, Briggs body build date +/-Aug 1930 68B fixed seat Cabriolet
kimeccles is offline   Reply With Quote
Old 03-12-2018, 11:14 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: running board rubber glue?
I have only used contact cement so I can't help you with experience but if I were in your shoes I would add the adhesive.
Old 03-13-2018, 01:07 AM   #3
burner31
burner31's Avatar
I have new mats that I will be installing soon, no self adhesive on these, I'll be using some of the super 3M stuff.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 03-13-2018, 07:31 AM   #4
daren007
3m1300l
daren007 is offline   Reply With Quote
Old 03-13-2018, 07:49 AM   #5
ronn
Barge rubber cement...............
Old 03-13-2018, 09:07 AM   #6
wrndln
I used the good stinky Weldwood contact cement (not the crappy worthless water based stuff) to install the runningboard matting on my 28 coupe. The problem was the glue created bubbles under the matting. The matting laid down nicely, but a little later, bubbles started forming. It was a tough job to try to get rid of the several medium sized bubbles that formed on each board. I am going to use 3M 90 spray adhesive to glue the matting on my 29 phaeton's runningboards.
Rusty Nelson
Old 03-13-2018, 09:19 AM   #7
chap52
chap52's Avatar
3M spray is much easier to get on evenly and avoid bubbles.
chap52 is offline   Reply With Quote
Old 03-13-2018, 10:46 AM   #8
Afordman31
Afordman31's Avatar
The last Swap Meet that I attended I spoke with a fellow that sold running board rubber and installed them. I asked what adhesive he used and he showed me this: GM 550 Polyurethane Adhesive Sealant Fast Cure.
Afordman31 is offline   Reply With Quote
Old 03-13-2018, 01:30 PM   #9
wrndln
Afordman31,
Is the GM adhesive a spray or is it applied another way (brush maybe)? I am about ready to put the matting on my 29 phaeton runningboards and don't want to have trouble(bubbles) like I did with the coupe using contact cement.
Rusty Nelson
Old 03-13-2018, 01:48 PM   #10
hardtimes
hardtimes's Avatar
3M makes SEVERAL differing spray adhesives. I've used different types of 3M spray, depending on what I need to happen with job. For instance, one type spray tacks/dries more slowly and you get a small window for shifting part. Whereas, another spray keeps the part(s) in place immediately. Choose wisely. All are great at what they do !
hardtimes is offline   Reply With Quote
Old 03-13-2018, 02:39 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
What was it like in "bygone" days, WITHOUT the modern GLUES/ADHESIVES, that we enjoy NOW? They'd glue something, let it sit for DAYS & it'd jist fall apart +=*$^%#$^ (PROFANITY that I can't display HERE!)
Bill Cleantalkersometimes
"THE ASSISTANT GURU OF STUFF"
Old 03-13-2018, 08:17 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
In the old days they had good glue from horses.
Old 03-14-2018, 08:02 AM   #13
Afordman31
Afordman31's Avatar
Originally Posted by wrndln View Post
Afordman31,
Rusty Nelson
Was in a tube Rusty, not spray. He said that there was working time and that he had weighted the running board rubber after getting it in position!
Old 03-14-2018, 08:38 AM   #14
BILL WILLIAMSON
From their HOOVES, I "think"???
How about JACKASSES/DONKEYS/BURROS/MULES/ETC ???
Bill Pondering again
Thread Tools
Display Modes
