Old 03-12-2018, 12:44 PM   #1
KCTA Chris
KCTA Chris's Avatar
Default Installed the Simmons Super Power head
Forced myself to park the truck a couple weeks and do maintenance, while at it finally installed the Simmons head. Always something: broken head bolts (ended up leaving some old studs in place) and after 50k miles on an unknown rebuild/babbitt a few things that have me thinking about a fresh block build in the future. Reading here had me nervous about the premium silicone gasket so went with a Fel-Pro 7013 R4. Then on the second re-torque broke the water neck even though I used the match trick and checking against for flatness. Also the plugs move placing it right in the way of the spark advance rod, a little bend should fix.
All that fuss and I still enjoyed working on it.
Now rebuild those the twin Simmons carbs!
KCTA Chris is offline   Reply With Quote
Old 03-12-2018, 01:00 PM   #2
TinCup
TinCup's Avatar
Default Re: Installed the Simmons Super Power head
That's a thing of beauty. Now you need a Simmons Carb like mine.
Sooner Model A Club of Oklahoma
TinCup is offline   Reply With Quote
Old 03-12-2018, 01:26 PM   #3
KCTA Chris
KCTA Chris's Avatar
Thanks!
I've got two thanks to Jim Huseby. Ran one for a while.
Rebuilding both is next on the list!
Old 03-12-2018, 05:08 PM   #4
AL in NY
AL in NY's Avatar
You won't have problems with the water neck if you only use black silicon gasket maker insist of the usual water neck gasket. I leave the gasket out and just use black RTV silicon instead of the gasket. Never had a problem breaking the water neck this way
AL in NY
AL in NY is offline   Reply With Quote
Old 03-12-2018, 11:33 PM   #5
Anteek29
Anteek29's Avatar
I am in agreement on using RTV
Alan
1929 Special Coupe
1941 Pick-Up
Anteek29 is offline   Reply With Quote
Old 03-13-2018, 05:29 AM   #6
Ed Saniewski
Ed Saniewski's Avatar
Me too, just don't crank down right away with the torque wrench, let the gasket maker set up for a bit.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
https://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 03-13-2018, 06:47 AM   #7
Bob-A
Bob-A's Avatar
Thumbs up Re: Installed the Simmons Super Power head
I've also got a "Simmons Super Power Head" and some Simmons carbs to run on my "A". If and when I ever get off my butt and do it! My 1933 Simmons catalog lists two different high compression heads for the Model-A: a 5-to-1 and a 5.5-to-1 head. Which one my head is I have no idea.
Bob-A
Bob-A is offline   Reply With Quote
Old 03-13-2018, 12:38 PM   #8
KCTA Chris
KCTA Chris's Avatar
Bob-A
Wow, I've never seen the catalog, can you could scan it?
I didn't know there were two either, I see on fordgarage.com he list Simmons at 6.1. I had a friend ask to CC this head but my in my stubborn rush to install I neglected to take him up on the offer. Now wish I had!
Old 03-13-2018, 03:28 PM   #9
Joe K
Joe K's Avatar
Painting the head red would make it go even faster...
Snicker.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-13-2018, 03:44 PM   #10
Bob-A
Bob-A's Avatar
KCTA Chris,
Vincent Falter (Ford Garage) has also asked me to scan some pages in the catalog for him too. I'm not much of a computer whiz, but I'll try soon and let you know.
Bob-A
Old 03-13-2018, 04:34 PM   #11
Synchro909
Water outlet neck: I have never used anything but a smear of silicone and I've never broken one.
This is a private message. Please donít read it.
Old 03-13-2018, 05:03 PM   #12
KCTA Chris
KCTA Chris's Avatar
Thanks Bob! Larger scans are great, can help walk you through if needed. Purdy Swoft was collecting Simmons (this is a head he graciously sold), he may have more info on identification too. I'm always learning, not sure what happened on the water neck, light file and checked both with a straightedge, paper gasket with light silicone and used the paper matchsticks. Popped right after torque, maybe it was just its time to go. Just silicone next.
Cracked the Simmons Carbs apart, thats this weeks challenge.
Painting the head red... what happens if just paint the whole truck?
Old 03-14-2018, 11:09 PM   #13
CWPASADENA
CWPASADENA's Avatar
X2
Chris W.
CWPASADENA is offline   Reply With Quote
Old 03-14-2018, 11:54 PM   #14
3.6rs
3.6rs's Avatar
Why black and not blue ??
3.6rs is offline   Reply With Quote
Old 03-18-2018, 10:13 PM   #15
KCTA Chris
KCTA Chris's Avatar
Done. Noticeable difference in power too!
Added a couple videos on youtube:
https://youtu.be/Xv2cOJxxzNI
https://youtu.be/jRBsovkErhA
Old 03-18-2018, 11:45 PM   #16
diomed
diomed's Avatar
Aesthetics
kris
diomed is offline   Reply With Quote
Old 03-19-2018, 12:29 AM   #17
Y-Blockhead
Y-Blockhead's Avatar
What? No burnouts??
Y-Blockhead
'30 Briggs Town Sedan
_________________________________
And once again that is just my 1Ę worth.
Old 03-19-2018, 09:55 AM   #18
KCTA Chris
KCTA Chris's Avatar
Originally Posted by Y-Blockhead View Post
What? No burnouts??
Last time I tried that I discovered the downfall of the riveted U joint!
Holding speed on the local hill is all I need.
Thread Tools
Display Modes
