Old 03-12-2018, 07:36 AM   #1
old Tom
Default lights
When the steering wheel is turned the headlights will flicker off and on. Does this meant there is a short in the wires running through the steering column?.How is the best way to repair that.?
old Tom is offline   Reply With Quote
Old 03-12-2018, 10:19 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: lights
Is the light switch handle also moving some as you turn the wheel?
Old 03-12-2018, 10:21 AM   #3
Will N
Will N's Avatar
Default Re: lights
It's more likely that the horn rod is a bit of a tight fit in the steering shaft, and the horn rod (which operates the light switch at the bottom of the steering column) is spinning a little when you turn the wheel. When you turn the wheel, do you see the light lever move?
Will N is offline   Reply With Quote
Old 03-13-2018, 05:13 PM   #4
old Tom
Default Re: lights
Are you saying that when you move the light switch handle by the horn button that it operates a rod and the electrical light switch is at the bottom of the steering column. Thank You,
Old 03-13-2018, 05:35 PM   #5
Mike Peters
Mike Peters's Avatar
Default Re: lights
Default Re: lights
Yes Tom. The light switch handle under your horn button is a long rod running straight through your steering column that turns the light switch at the base of the steering column. If working properly, that switch will be unaffected by steering wheel movement. If not and it's binding in the steering column, then it will turn your lights on and off as you drive, and you don't want that.
Mike Peters is offline   Reply With Quote
Old 03-13-2018, 05:36 PM   #6
oldforder
Default Re: lights
Yes
oldforder is offline   Reply With Quote
Old 03-13-2018, 11:03 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
Default Re: lights
Tom, Yes as already mentioned, the light switch is at the bottom of the steering column. There are no "wires running through the steering column".
Y-Blockhead
'30 Briggs Town Sedan
_________________________________
And once again that is just my 1 worth.
Old 03-14-2018, 07:37 AM   #8
old Tom
Default Re: lights
Thank you all very much I haven't had a Model A since I was 14 and that was a while ago. I just got the car last Sat. One more question if no wires run through the column how does the horn work when you push the button. There is a wire running from the B side of the generator C/O to the horn and than down to a wire harness. The horn does not work. I haven't tried to hot wire it as yet to check it. I will check the horn rod as soon as I get time. Mr Peters is that a W6 in your picture?
Old 03-14-2018, 08:57 AM   #9
Will N
Will N's Avatar
Default Re: lights
The horn is wired so that it is always hot, and all that is needed is a ground to complete the circuit. The wire coming off the generator cut-out to the horn is hot, and the other wire from the horn to the light switch is the ground. The end of the light switch rod has a contact that makes contact with the horn ground wire. When you push the horn button, it completes the ground path and the horn sounds. I never took a light switch rod apart, but I suspect there IS a wire that runs inside the rod from the contact down at the light switch end up to the horn button.
Old 03-14-2018, 10:26 AM   #10
redmodelt
redmodelt's Avatar
Default Re: lights
The horn grounding wire is the only one running thru the shaft. It is inside the light rod tube not free floating in the shaft. You could be missing the bushing that goes at the top or the rod has a small bend in it and is rubbing just enough to turn just a little bit with the shaft.
http://www.snydersantiqueauto.com/light-rod-bushing
Old 03-16-2018, 09:25 AM   #11
Mike Peters
Default Re: lights
Tom: Yes. It's actually a 1953 Super W6 International. You definitely know your tractors!
Old 03-18-2018, 12:59 PM   #12
old Tom
Default Re: lights
A few posted that there should be a wire running up the horn rod to the horn button, the other end of the wire connects to the horn grd terminal. My question is what do you connect the wire to at the top,so the horn button contacts it when you push it. Mine does not have a wire running through the horn rod. We can make the horn work by grounding the contact at the light switch. Can you remove the light switch lever and the horn button from the end of the shaft? I think I might have a replacement shat on mine.
Old 03-18-2018, 01:26 PM   #13
Bob C
Default Re: lights
This is what you need. https://parts.modelastore.com/show_Product.asp?ID=3344
Bob
Bob C is online now   Reply With Quote
Old 03-19-2018, 09:37 AM   #14
Jerry in Shasta
Jerry in Shasta's Avatar
Default Re: lights
I use some WD40 and a .45 Cal. bore bush to clean the steering shaft each time I take one out.
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Thread Tools
Display Modes
