Old 11-07-2017, 07:43 PM   #1
jdpalmer
jdpalmer's Avatar
Default Main engine insert
I have an engine that was inserted about 10 years ago and never run until now and the rear main galled. nothing hurt but insert now I can't find a replacement. I have tried Clevite and Summit and nothing with this number.
S8745SA .020 has anyone heard of this main insert.
Jimmy Palmer
jdpalmer is offline   Reply With Quote
Old 11-07-2017, 09:15 PM   #2
Bob C
Default Re: Main engine insert
Here is a list of some bearings that were used for the mains.
Model A Main Bearings
Fed Mogul PN .Undersizes Width Std. Shaft size Housing Bore
International Harveste
r
1456SB 2-10-20-30 1.063 1.6230/1.6240 1 7760/1.7770
British Leyland (rod brgs)
4-2965CP 10-20-30-40 .880 1.6254/1.6259 1.7705/1.7710
Onan (rod brg)
3180SB 10-20-30 1.000 1.6252/1.6260 1.7505/1.7510
Standard Motors (rod brg)
4-65290RA 10-20-30 .692 1.6250/1.6255 1.7705/1.7710
Old 11-07-2017, 09:24 PM   #3
Railcarmover
That was made by AE bearings,a federal mogul company..Ive done enough brother,you can take it from here.BTW,why did it gall?
Railcarmover is offline   Reply With Quote
Old 11-08-2017, 09:27 AM   #4
john in illinois
john in illinois's Avatar
You might call Rich at AER. He is expert with inserted engines and very helpful.
http://antiqueenginerebuilding.com/
John
john in illinois is offline   Reply With Quote
Old 11-08-2017, 11:02 AM   #5
glenn in camino
glenn in camino's Avatar
Last time I went through my B engine I had to call the guy who built it to ask where he got the inserts. They turned out to be from a Toyota.
Old 11-08-2017, 11:14 AM   #6
Benson
Benson's Avatar
Old 11-08-2017, 11:24 AM   #7
d.j. moordigian
d.j. moordigian's Avatar
https://picclick.co.uk/MG-MGA-MGB-Gl...l#&gid=1&pid=1
Your welcome...
d.j. moordigian is offline   Reply With Quote
Old 11-09-2017, 09:05 PM   #8
jdpalmer
jdpalmer's Avatar
I couldn't find anyone who handled this bearing it was listed but not available. I called antiqueengineering rebuilders and they have the full length mains that should replace these as the housing bore is the same. The cause was oil not getting across the insert. The oil feed hole was almost covered up by the insert but if a oil grove had been put in it I was told by another rebuilder that it would have got enough ol but there was no path across the insert.
Jimmy Palmer
Old 11-09-2017, 10:52 PM   #9
Railcarmover
That sucks..the whole game is attention to detail,If the cat assembling it had stopped and really looked at what he was doing..oh well,good luck finding the insert..hell Id check the other mains and the rods just to be safe..
Old 11-09-2017, 11:25 PM   #10
Flathead
Flathead's Avatar
If the AER inserts fit that is great news. My engine has been real happy with them.
Flathead is offline   Reply With Quote
Old 11-10-2017, 11:06 AM   #11
d.j. moordigian
It's NOT that hard! They fit MGA and MGB ,...I gave you , I thought , enough information.
This is what I found off ebay...
https://www.ebay.com/itm/MGA-1600-MG...hX3aAS&vxp=mtr
Old 11-24-2017, 07:17 PM   #12
jdpalmer
jdpalmer's Avatar
I miked the bore of the crank caps to block and called Antique Engine Rebuilders. They had the inserts with the .020 that fit perfectly. These are one piece with correct oil holes beveled edges and oil grove all the way around. By the way they shipped fast and reasonable and cheaper than any catalog as they make these that are sold in all of your catalogs. I now have new inserted rods coming that they manufacture.
Jimmy Palmer
Old 11-25-2017, 12:58 PM   #13
john in illinois
Jimmy I have an A with AER parts and have been happy with itfor 25,000miles.
You should be set.
John
Old 12-07-2017, 04:37 PM   #14
jdpalmer
jdpalmer's Avatar
All done the AER inserts and new rods fit perfectly ready for motor install
Jimmy Palmer
Old 12-07-2017, 05:12 PM   #15
Dave in MN
Dave in MN's Avatar
What was your finished clearance between your crankshaft and the inserts at each journal? I assume you checked it when assembling with Plastigage or a bore gauge?
Good Day!
Dave in MN is offline   Reply With Quote
Old 12-10-2017, 09:45 PM   #16
jdpalmer
jdpalmer's Avatar
.0015
Jimmy Palmer
