07-20-2019, 07:52 AM | #1 |
New type of motor mounts what do you think?
Has anyone tried these motor mounts and if so what are your thoughts?
https://www.snydersantiqueauto.com/P...earchByKeyword |
07-20-2019, 08:08 AM | #2 |
Re: New type of motor mounts what do you think?
Probably works - but a little bit of vibration in the passenger compartment is part of the Model A experience. Not sure the benefit is worth the cost and effort or originality compromise. Welcome feedback from someone that tried it.
07-20-2019, 10:46 AM | #3 |
I think Float-a-Motor mounts can hardly be called "New" as they have been around for more than a few years.
That said, I have never tried the front mount. The stock front mount seems to work fine. And I refrain from drilling holes. My car came with the rear mounts and I haven't seen the need to remove them. I have replaced the rubber "biscuits" a few times over the years. Last edited by Y-Blockhead; 07-20-2019 at 11:11 AM. |
07-20-2019, 10:49 AM | #4 |
Not exactly new. Most I have talked to don't use the front Float a motor, but do the back. My pickup had the back ones on when I bought it, and it is noticably smoother. I like them.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
07-20-2019, 04:38 PM | #5 |
I use the FOM rear and stock front. Do not see a reason to change.
John
Welcome each day |
07-20-2019, 04:55 PM | #6 |
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
07-20-2019, 07:05 PM | #7 |
not new at all. I have that mount a long with the float a motor in the rear. and when I get off my a`s I will do away with them both. some people like them I for one do not.
I broke my gas line three times from to much movement, and I was lucky that all three times it did not catch fire. now I have a breaded stainless flex line from the valve the Carb, |
07-21-2019, 11:44 AM | #8 |
I cut mine into 2 pieces. Don't know if it reduced vibration, but just seemed to be more sturdy than stock.
07-22-2019, 08:13 PM | #9 |
just out of curiosity, does anyone briefly know how suspension changed in the '32 "B' and V-8 models, though I know the frame was entirely different.
