10-10-2017, 04:25 PM | #1 |
U-joint Play
There is about 1/8 inch play in the four shaft ends of my U-joint. And, the shafts are no longer round. (see attached pic)
I'm thinking it's time to retire. Your thoughts? And don't laugh.
Ray White |
10-10-2017, 05:38 PM | #2 |
Re: U-joint Play
I don't think I'd retire just because of a bad u-joint, but, that one has seen better days. [ smiley face]
10-10-2017, 05:51 PM | #3 |
Re: U-joint Play
Looks about ready to blow! Must have been noisey.
10-10-2017, 06:20 PM | #4 |
Re: U-joint Play
Strangely, I never heard a peep out of it. I'm just going in to change the clutch, which chattered like heck.
Ray White |
10-10-2017, 07:07 PM | #5 |
Re: U-joint Play
Uh, oh
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
10-10-2017, 08:43 PM | #6 |
Re: U-joint Play
That joint ain't fit for the road, and is way past time to replace it. |
10-10-2017, 09:07 PM | #7 |
Re: U-joint Play
10-10-2017, 09:25 PM | #8 |
Re: U-joint Play
I've heard that the modern replacement unis are not very good even if they fit. Is there another option other than Bert's, like maybe rebuilding them?
10-10-2017, 11:09 PM | #9 |
Re: U-joint Play
Steve Becker is sending a good original.
Ray White |
10-11-2017, 07:58 AM | #10 |
Re: U-joint Play
Mine was a helluva lot worse than that one when I finally replaced it. The two riveted halves were looser, and the bearing surface on one shaft was nearly half gone. It was all caused because I didn't realize just how much of the right kind of grease those things need.
I now carry the worn out one in my trunk for show-and-tell when people ask about repairs and maintenance. Ken
Style beats speed any day, and with a lot fewer tickets. |
10-12-2017, 11:18 AM | #11 |
Re: U-joint Play
Aw come on... run it 'til it's broke!
10-12-2017, 11:34 PM | #12 |
Re: U-joint Play
For sure! What the heck.........a little play didn't stop this guy.
10-15-2017, 06:33 AM | #13 | |
Re: U-joint Play
Ken
10-15-2017, 12:09 PM | #14 |
Re: U-joint Play
Couldn't be much worse that the one that was in my truck when I found it.
Dave / Lincoln Nebraska |
10-15-2017, 04:25 PM | #15 |
Re: U-joint Play
I've just acquired a RHD 1933/4 gearbox (very rare over here) and it has the U joint still on it. Will it fit a Model A? It's not in bad condition and looks like it should fit.
10-15-2017, 07:44 PM | #16 |
Re: U-joint Play
Okay, you win. Mine wasn't nearly that bad.
10-12-2017, 12:09 PM | #17 |
Re: U-joint Play
Check 29 Cabriolet further down, he did.
10-12-2017, 07:50 PM | #18 |
Re: U-joint Play
Add lots of grease in the fitting under the U joint.
10-13-2017, 02:46 AM | #19 |
Re: U-joint Play
The rivetet version is not to be rebuilt !!!
Once you see damage , there is no doubt... Test (if you see no damage): Hold the U-joint at one end and shake it. Once it wobbles without resistance and you hear noises.... ITS TIME TO REPLACE ! The "new" parts to be sold by the vendors are not best quality. (Any new junk will be even better than the ones in those pics.) Use lots of grease ! Have fun Chris I replaced the U-joint in my car with a "new" snyders U-joint 5 years ago. Even it looked like a strange rough log, its still "alive" |
10-13-2017, 09:57 AM | #20 |
Re: U-joint Play
I have a good U-Joint for sale on the Swap Meet page.
