Old 03-14-2019, 11:44 PM   #1
Steve Plucker
Default Ford's Cadmium Plating process
The following article describes Ford's Cadmium plating process of brake shoes (and more than likely other cad plating items) starting on page 3 to 4.
http://www.plucks329s.org/pdf/brakes...hoe_lining.pdf
Interesting.
Pluck
Old 03-15-2019, 05:27 PM   #2
burner31
burner31's Avatar
Default Re: Ford's Cadmium Plating process
Having beem a plater for over 20 years this was an interesting article to read. But we would always bake the items after plating to relieve hydrogen embrittlement, I wonder if they knew about hydrogen embrittlement back in the day?
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 03-15-2019, 05:39 PM   #3
Synchro909
Synchro909's Avatar
I suspect not. In the 1970's (I think but it may have been earlier), Kenworth trucks here had a nasty habit of certain blots loosing their heads. In one yard, an observant worker noticed a couple of bolt heads under one of the NEW trucks. Upon investigation, it was found that Hydrogen embrittlement had caused the heads to come off some of the bolts holding the steering boxes to the chassis. Either Kenworth were hopelessly incompetent or the phenomenon wasn't known. I prefer to think the latter.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 03-15-2019, 10:32 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Help me out. Would embrittlement play a significant roll in the case of brake shoes, bolts/fasteners I understand but brake shoes? (I read that the phenomenon was discovered in 1875)
Has anyone heard of the shoes cracking for any reason?
Old 03-16-2019, 12:13 AM   #5
Synchro909
Synchro909's Avatar
Wow, that makes Kenworth look pretty foolish!
Old 03-16-2019, 12:45 AM   #6
40 Deluxe
Or it could have been a case of counterfeit bolts (some supplier selling Kenworth cheap bolts with a name brand stamped in the heads).
Old 03-16-2019, 12:57 AM   #7
burner31
burner31's Avatar
I would not think that the embrittlement would have much negative effect on the brake shoes on a 40 hp vehicle, but when you get to hi-powered vehicles and aircraft...yes.
Keith
Shawnee OK
'31 SW 160-B
Old 03-16-2019, 10:43 PM   #8
Synchro909
Synchro909's Avatar
Could be but I would have thought their quality cotrol should have picked it up.
