Old 05-21-2020, 09:51 PM   #21
DBSHELTON
Default Re: B Carb and B Distributor
Been playing with the initial timing. Seems to be good with an initial of 18. Is that correct?
DBSHELTON is offline   Reply With Quote
Old 05-22-2020, 12:13 AM   #22
Jack Shaft
Id say its too far advanced if your readings are correct.Ive found 8 degrees initial to be optimal for me,but my compression is 7.5 to 1,running a late b cam,holley 94 and header,my volumetric effciency is higher than a stock configuration..
Old 05-22-2020, 05:14 AM   #23
DBSHELTON
I started out at 9 but the engine runs toward the warmer side. I am still running the stock A head and carb.
Old 05-22-2020, 06:35 AM   #24
Bob-A
Bob-A's Avatar
Thumbs up Re: B Carb and B Distributor
I believe Mac's is selling "B" points and condensers now. Also, don't forget the "B" dizzy uses slightly longer bronze spark plug leads. I finally put a "B" dizzy on my '31 roadster and it is probably the best thing I've done for it.
Bob-A
Bob-A is offline   Reply With Quote
Old 05-22-2020, 08:42 AM   #25
daren007
How would you verify “10” percent.
daren007 is offline   Reply With Quote
Old 05-22-2020, 01:10 PM   #26
Jack Shaft
Actually verify? Why? Do it,if you like it run it,if not tear it off and sell it.Thats the fun part,flinging it against the wall,if it sticks you feel good,if not,move on.
Old 05-22-2020, 02:00 PM   #27
Purdy Swoft
Purdy Swoft's Avatar
I still prefer the original distributor , its less complicated . I like having the ability to retard and advance the distributor myself . I'm use to it and consider it as part of the model A charm ..
Old 05-22-2020, 02:11 PM   #28
Purdy Swoft
I posted in the wrong place .
