Old 07-06-2018, 12:30 PM   #1
father-son
Default (Advice/tips)Leaking gas from rivets surrounding shutoff valve
Well looking for tips and advice on how to go about fixing small leak from the rivets that surround the shutoff valve. We were dealing with a leaky valve before (now fixed) and now it seems that the tank itself has tiny cracks allowing a small amount of gas out through the 3 rivets. Thanks again!
File Type: jpg 7DE6E239-97EB-40B0-9781-AFB0B8B1A2EB.jpg (26.8 KB, 237 views)
File Type: jpg E4842EA0-50D5-441A-BBFE-79EDC376547C.jpg (28.4 KB, 247 views)
File Type: jpg A1773C0C-9EAE-4A36-9C21-0183C05C64C2.jpg (23.8 KB, 227 views)
father-son is offline   Reply With Quote
Old 07-06-2018, 12:54 PM   #2
F.M.
Default Re: (Advice/tips)Leaking gas from rivets surrounding shutoff valve
You are going to have a LOT BIGGER problem if you leave the rubber hose like it is !!.. Get an original type line on it quick..
F.M. is offline   Reply With Quote
Old 07-06-2018, 02:03 PM   #3
Gary WA
Gary WA's Avatar
The real fix is to remove tank and properly fix,not good! Ditto F.M.!
www.whidbeymodelaclub.com
Old 07-06-2018, 02:18 PM   #4
Growley bear
Remove the tank and have a professional repair it. You may not like the bottom line but it's better than a fire.
Growley bear is offline   Reply With Quote
Old 07-06-2018, 02:57 PM   #5
JOHN CT
JOHN CT's Avatar
Step one please remove the rubber hose!!
I had the same problem with my tank. I cleaned the area and cleaned the area again. Then I applied JBweld for gas,been leak free for 2 years. I do check it regularly if the leak returns I will remove the tank and have it Professionally repaired !! You never should have gas leaking.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is online now   Reply With Quote
Old 07-06-2018, 03:08 PM   #6
Jwilli
Jwilli's Avatar
It is time for tank removal and repair.
Jwilli is offline   Reply With Quote
Old 07-06-2018, 03:17 PM   #7
father-son
the hose is there to drain the tank
Old 07-06-2018, 03:24 PM   #8
father-son
Agreed, we are getting it repaired; no epoxy or JB weld for this one. We have the body off and want it done right before we re-assemble. 29 Tudor matching numbers with 1973 Title out of Michigan. Not repainting it; long block engine rebuild by Rich at Antique Engine in Skokie, Ill.
Old 07-06-2018, 03:39 PM   #9
Jwilli
Jwilli's Avatar
Smile Re: (Advice/tips)Leaking gas from rivets surrounding shutoff valve
Sounds like a smart decision to me.
Old 07-06-2018, 06:51 PM   #10
JOHN CT
JOHN CT's Avatar
I agree with you donít use any kind of epoxy to repair. I didnít know the body was off and your doing a restoration. My problem was my car is done just painted and the gas tank was removed and sealed by a local radiator shop.
So I did the JB weld trick. I didnít want to remove the tank and ruin a new paint job!
31 Tudor
66 Bonneville
Old 07-06-2018, 07:36 PM   #11
father-son
I would have done the same thing if it was going to mess up the paint.
Old 07-09-2018, 06:06 PM   #12
father-son
Jwilli, I am located in Kennesaw, GA as well. We are nearing completion of our 29 Tudor but are looking for a shop in the area that can check our wiring. Any recommendations?
Old 07-09-2018, 06:46 PM   #13
mike48750
What would be a proper repair for this problem? Remove the tank and replace the damaged metal? How did they buck those rivets when the cars were new, special bucking bar? Seems like it would be a fun project. Mike
mike48750 is offline   Reply With Quote
Old 07-09-2018, 06:59 PM   #14
wrndln
I believe the items riveted to the gas tank (steering column bracket, choke bracket and shutoff threaded insert) were installed (riveted) before the tank was electro-welded up. Before welding the heads of the rivets were accessible for bucking.
Rusty Nelson
Old 07-09-2018, 07:30 PM   #15
mike48750
Thanks for your answer wrndln. So could an "access" be cut out of the firewall side so as to "tighten" the leaking rivets with a rivet gun? My Coupe always "sweat" fuel from the rivets for the steering column bracket and I never fixed it properly, just smeared a little bar soap on the area and went on for another 6 months. Mike
Old 07-10-2018, 08:20 AM   #16
katy
katy's Avatar
Strange, I had a problem w/gasoline softening up JB weld to the point where it wouldn't hold.
Play it again Sam.
Old 07-14-2018, 11:11 AM   #17
DHZIEMAN
There is no short cut here to safety! Gasoline is dangerous, and the combination of a gas leak and a rubber hose inside the care is very scary! The pictures U provided depict a home made repair to save removing the tank.
I don't understand the rivets, but then again, I don't understand the rubber hose.
The only real solution is getting the tank removed and taking it to someone who can fix the problem or direct you to a good repaired available gas tank.
There are plenty of posts on tank removal based on the year of your Model A.
You will be much better off, fixing this right, AND GETTING RID OF THE RUBBER HOSE! And having a safe car to drive!!!!!
DHZIEMAN is offline   Reply With Quote
Old 07-15-2018, 08:15 AM   #18
katy
katy's Avatar
Suggest that you read the whole thread, especially post #7.
Play it again Sam.
Old 07-18-2018, 11:34 AM   #19
DHZIEMAN
There are time when my greatest accomplishment is just keeping my mouth shut!
Old 07-19-2018, 04:18 PM   #20
Kahuna
Kahuna's Avatar
Katy
If you have any alcohol in the gasoline, that will soften the J B Weld.
Straight gas won't affect it.
Jim
Kahuna is offline   Reply With Quote
