03-27-2015, 07:36 PM | #1 |
28-29 roadster rumble area inside
Does anyone have pictures of the inside of a 28-29 rumble compartment showing the vertical braces?
03-27-2015, 08:27 PM | #2 |
Re: 28-29 roadster rumble area inside
Glenn,
Dudley posted a picture showing the 2 vertical braces on the post you made a day or two ago. Didn't you see it? The link is pasted in below. Here's the deal. The front brace is bolted to the quarter panel/panel above the trunk with 2 bolts. The top of the rear brace is riveted with two countersunk head rivets with the head under the rain gutter - peened toward the outer part of the car. Both braces are riveted on the bottom of the braces with 3/16" rivets (three rivets for each brace) to the subrails. Two rivets are installed from the top and one form the inner side of the subrail. Rusty Nelson https://www.fordbarn.com/forum/showthread.php?t=164838 |
03-28-2015, 11:25 AM | #3 |
.......................................Well ?.................................................. ......
03-28-2015, 07:47 PM | #4 | |
03-28-2015, 07:50 PM | #5 |
