10-06-2019, 03:03 PM | #1 |
fuel line insulator
I'm having problems starting the car after shut down. I am going to install a carburetor insulator gasket. Taking it further and could I snap flexible plastic split wiring tubing over the fuel line running over the intake manifold to the carburetor.
10-07-2019, 04:31 AM | #2 |
Re: fuel line insulator
If you think you have heat soak through the steel line(s), it needs an insulating wrap - https://www.heatshieldproducts.com/b...ent-vapor-lock
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
10-07-2019, 11:28 AM | #3 |
A one inch spacer should help a lot. Also, set the float to the lowest level the book gives, more room to percolate without overflow into the engine.
10-13-2019, 08:12 PM | #4 |
