06-17-2019, 01:24 PM | #1 |
Engine Mount Bolt Torque
I’ve search but haven’t found the torque value for the front and rear engine mount bolts. Is there actually a torque spec or just snug and install cotter pin.
Thanks Dave |
06-17-2019, 01:49 PM | #2 |
Re: Engine Mount Bolt Torque
Tighten them good but not so much to distort the rubber.
06-17-2019, 02:01 PM | #3 |
I agree with the above. Being able to slip in the cotter pin is probably a good indicator.
Snug as a bug in a rug works. |
06-17-2019, 02:32 PM | #4 |
Thanks for the help, figured they shouldn’t be to tight as the rubber would distort and cause them to possibly split.
06-17-2019, 04:43 PM | #5 |
They do need to be tight, but only to the point that the rubber barely starts to bulge.
Alan |
06-17-2019, 07:12 PM | #6 |
