05-18-2019, 10:34 PM | #1 |
stuck rear hub help
My mate has a 48 that the rear wheel cylinders are leaking ,so he tries to remove the rear hub,we have the car on the hoist, proper puller on the hub ,no luck, tried every thing ,heated the hub ,no luck,the puller is a good quality Ford puller, it now needs a fix up as it distorted trying to get the hub loose.
We then heated the hub nearly red and still not loose. Any ideas, Our next step is to sacrifice the hub and cut it off, and save the axle. Lawrie |
05-18-2019, 11:11 PM | #2 | |
Re: stuck rear hub help
Charlie Stephens |
05-18-2019, 11:54 PM | #3 |
Lawrie, The only hub puller for that job is a KRW puller, and they do not distort. Your hub, if it is loose from the axle but still won't come off, may be held in place by the shoes hanging up on edges worn into the hubs. If that is what happened, then yes, drastic means must be taken to remove them. If, on the other hand, the drums are still stuck on the axles, then use the correct KRW puller and it will break free.
Alan |
05-19-2019, 12:17 AM | #4 |
I have the KR wilson puller, It wont break free.
It just started to swell the steel tube that holds it all together. Brakes are not hung up as the wheel turns easy. Lawrie |
05-19-2019, 12:26 AM | #5 |
Lawrie, I don't understand what could have happened. Please post pictures!
Alan |
05-19-2019, 07:39 AM | #6 |
05-19-2019, 08:07 AM | #7 |
I had it happen. And with the krw puller it would not budge.
The key was gawlled and jammed it together. Ended up splitting the hub. That's better then ruining the axle |
05-19-2019, 08:42 AM | #8 |
had a hub that had "spun" on the axle and the only way I could get it apart was to heat the hub to cherry red and pound on it with a 3 lb hammer, of course the hub and the axle were junk after that.
05-19-2019, 09:40 AM | #9 |
Cherry red doesn't always help, most of the time it works against you. You want the hub to expand and not the axle.
Problem I had was the key turned into a fish hook and wouldn't come off. Even after splitting the exposed area of the hub it would wobble but still was a fight getting it off. I split it inline with the key to keep from booting up the axle Mine had a near perfect brake drum so I just swapped the hub after getting it apart |
05-19-2019, 05:48 PM | #10 |
This was what I found on one of the hubs on my '41. I distorted an aftermarket puller trying to get it off. finally got it to break free by locking up the brakes and working between first and reverse. Needless to say the hub and axle are now junk so have replace both.
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand https://www.fordbarn.com/forum/album.php?albumid=580 |
05-19-2019, 06:12 PM | #11 |
Ewwww! That looks bad!
I had one that was really stubborn on my 35, the shoes were grooved into the drum enough that would not let it pull off. I used the KR Wilson puller but had to put a spacer in there to pull it out more to figure out what was going on. A 3/8” quarter inch drive socket worked for that. It still ended up ruining one of the brake shoes. The drum was already shot, but it looks like I can save the hub. |
05-19-2019, 10:53 PM | #12 |
Patiance is the key word here a good quality puller and some penetrating fluid that wont dry out you've done everything right just give the penetrating fluid time to work if your going to heat the hub best get some boilermakers heat crayons so you dont overheat the hub and damage it. Had this problem several times when working on older VWs same setup just keep the pressure on and give the joint a fresh squirt every time you go past it will let go just sometimes it takes longer than others
05-19-2019, 10:58 PM | #13 | |
I did this with a 28 model A before using a puller on the rear. Loosed the axle nut slightly and put the cotter back on. drove it for a day or two. Drums/hubs popped off. No idea if that helped...but. |
05-20-2019, 03:24 PM | #14 |
The best puller I found is a Snap On Blue point.
I guarantee this would pull them. It is the long taper that is very dry along with the key. I found a 39 coupe in the woods that sat there 40 or 50 years. The hood sides and the steel grill were completely gone and the Stainless moldings were laying on the ground all in like new condition. The body was rotted off the frame and I was able roll the body on it's side by myself. I dug the rear drums up out of the dirt and my puller tore the drums off bending the backing plates. Brute Force. G.M.
www.fordcollector.com |
05-20-2019, 03:30 PM | #15 |
Will keep you informed, yesterday ,after buggering two pullers, we have made up a setup that we can fit in a 10 or 20 ton porta power cylinder,
I have a grand parents morning at school this morning so will know more after lunch. Lawrie |
05-20-2019, 04:35 PM | #16 |
Consider this. If the hub and axle are welded together so hard that a KR puller and heat won't budge it, they are both junk. Cut it off with a plasma cutter or torch and get on with the fix. BE CAREFUL TO NOT NICK THE AXLE HOUSING WHEN CUTTING.
Check the under side of the housing for pitting. It may be junk also. |
05-20-2019, 05:35 PM | #17 |
seen more than one axle ruined by those KRW pullers. you need one like this never failed me yet.
05-20-2019, 05:40 PM | #18 |
Those are good for ruining studs and bending hubs.
05-20-2019, 05:42 PM | #19 |
Everything I have ever heard is counter to post 17. The Ford hubs are designed to be used with a KRW puller (the flanges on the hub fit the puller perfectly). Back when I had pre-49 Fords, I had a KRW puller and never had a problem pulling a hub. I did quite a few between myself and friends and folks that just heard I had one.
05-20-2019, 05:47 PM | #20 |
This is a snapon blue point and grabs the hub the same way a KRW does but opens and closes like a clam
