Old 10-09-2019, 02:33 PM   #1
Leatherback 57
Leatherback 57's Avatar
Default Castor angle
Does anyone have a formula for castor measurements . Les Andrews book says at 11in difference of 1in is . 09 or 5.1deg.
Mine is at 12in and a difference if 1.5 in or 0.125
I'm thinking around 7degrees??
Leatherback 57 is offline   Reply With Quote
Old 10-09-2019, 02:55 PM   #2
Roger Green
Default Re: Castor angle
Yes, the arc tangent of 1.5/12 is 7.13 degrees.
Roger Green is offline   Reply With Quote
Old 10-09-2019, 04:55 PM   #3
Leatherback 57
Thumbs up Re: Castor angle
Great, Thanks. Should be good.
Old 10-09-2019, 05:48 PM   #4
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Just by a angled scaled magnetic protractor from your local lumberyard and stick it to the axle and read the °’s
Old 10-10-2019, 03:25 PM   #5
Patrick L.
Patrick L.'s Avatar
7º of caster is quite a bit. They are originally set for 5º which is still quite a bit.
The car will still probably track well at speed, but, the steering wheel probably will not want to return very well on its own during a slow turn.
Old 10-10-2019, 10:13 PM   #6
Railcarmover
its an old hotrodder trick,the more caster or king pin inclination the less steering effort you have,add enough it will feel like power steering,till it dives into a turn..
Railcarmover is offline   Reply With Quote
Old 10-10-2019, 10:33 PM   #7
Pete
Pete's Avatar
You may want to rethink that.
Old 10-11-2019, 12:41 AM   #8
SAJ
SAJ's Avatar
Hmm. The action of caster lifts the sprung weight up as the wheels turn if I am not mistaken. I often am!!
This should give heavier steering and more self-centreing action,
SAJ in NZ
SAJ is offline   Reply With Quote
Old 10-11-2019, 01:15 AM   #9
updraught
updraught's Avatar
It's like a shopping trolley ...
https://www.youtube.com/watch?v=Gh7gWJAvOvs
updraught is offline   Reply With Quote
Old 10-12-2019, 04:10 PM   #10
duke36
5 deg.measured per post 4 at the axle ends next to the king pins. The axle in the middle may be different due to age, etc.
