09-27-2019, 06:56 AM | #1 |
Greasing
Hi Gents
I’m having hard time getting grease into king pins. Is it necessary to take weight off front end?
Thanks - 30-9 1939, 1940 |
09-27-2019, 07:17 AM | #2 |
Re: Greasing
No, it really shouldn't make any difference. Have you been able to grease them in the past?
09-27-2019, 07:18 AM | #3 |
Re: Greasing
No shouldn't have to jack it up. Usually it is because the grease is old and dried up in the fittings. Screw them out and clean them and while you have them out check that the grease hole in the bushing is lined up with the fitting.
09-27-2019, 07:24 AM | #4 |
Re: Greasing
Get your self one of these.
https://www.summitracing.com/parts/wmr-w54209/overview/ |
09-27-2019, 07:37 AM | #5 |
Re: Greasing
Ok thanks. Let me try taking off zests and cleaning.
Btw is there drawings showing all fittings to be greased. I checked owner manual and vanpelts site without finding.
09-27-2019, 08:12 AM | #6 |
Re: Greasing
09-27-2019, 08:23 AM | #7 |
Re: Greasing
If you have an original owners manual, you will find a "lubrication and maintenance chart" in the center of the manual. Any part marked with an "A" indicates that it should be greased with pressure gun lubricant. All other points to be oiled or greased are depicted on this chart. Ford recommends this maintenance to be done each Fall and Spring.
09-27-2019, 08:41 AM | #8 |
Re: Greasing
Found it thank you!
09-27-2019, 08:54 AM | #9 |
Re: Greasing
Actually one should always take the weight off of the spindle pins when greasing. That isn't backyard mechanic advice but rather professional (schooled) advice.
09-27-2019, 09:54 AM | #10 |
Re: Greasing
Kube, any input as to why there is an advantage?
09-27-2019, 10:22 AM | #11 |
Re: Greasing
I always jacked up a vehicle because I just thought it was easier to get them to take grease. Some times if I had a helper I would have them turn the steering wheel back and forth to get the grease all around the pin..... Mark
09-27-2019, 11:26 AM | #12 |
Re: Greasing
If old grease is dry you can warm up with a heat source. I had a old truck that most fittings would not take grease and a few minutes of the torch fixed them. You should try a heat gun first.
09-27-2019, 11:41 AM | #13 |
Re: Greasing
Are you wanting a car or a truck lube chart? Here is a 1940 car chart.
09-27-2019, 11:47 AM | #14 |
Re: Greasing
I was taught that the side of the pin that was weighted against the bushing would not be easily lubricated. To avoid this possibility, simply removing the weight from the pin assured an even application of lubricant.
Now, away from my schooling and in to the real world... I'd witnessed numerous times, mostly the old Ford I-Beam trucks wherein the pins would wear seemingly prematurely. These were on client's vehicles that were in fact well maintained. The common denominator? Vehicles were lubricated with the weight on them.
09-27-2019, 07:55 PM | #15 |
Re: Greasing
have you ever herd of a grease pit. years ago when they were in use you drove the car over it & it was greased from below with all four wheels on the grond how quick we forget but then again a lot of you are young & never saw them
09-27-2019, 09:46 PM | #16 |
Re: Greasing
there are 2 reasons to raise vehicle 1 lifting the axle will take the weight off the thrust race and allow it to take grease correctly 2 raising the vehicle will take any side load off the upper and lower bushes ensuring that they are fully lubed not just on one side also [instructions from avon meritor worlds largest and longest manufacturer of beam and solid type axles ] They also recommend rotating from lock to lock while lubing
09-28-2019, 07:36 AM | #17 |
Re: Greasing
09-28-2019, 08:28 AM | #18 |
Re: Greasing
Very true. The point that Kube makes seems perfectly logical. The other side of the argument points to real life experience.
I worked in grease pits, and under the old Globe drive on hydraulic lifts. The fact that that's the way we did it, does not change the fact that with no weight on the axle, the grease can better flow into all areas. Let us know what worked.
Enjoy yer day. Tom Hate can't fix what it started. |
09-28-2019, 10:08 AM | #19 |
Re: Greasing
My Model A only takes grease with the car jacked up
09-28-2019, 10:21 AM | #20 |
Re: Greasing
Totally incorrect, all weight should be taken off front end when greasing the king pins ! I professionally maintained equipment for over 40 years.
"If you do not want to hear the answer, don't ask the question!" |
