08-02-2019, 03:21 PM | #21 | |
Re: Orange/LA county recommendation for Diff. Rebuild
I would think seriously about replacing that axle. More than likely it suffered some unusual stresses at some point which eventually resulted in that failure. NOS or good used ones are still around. |
08-02-2019, 04:58 PM | #22 | |
Charlie Stephens |
08-03-2019, 10:25 AM | #23 |
There it's a little play in and out of the axle with the drive shaft. Maybe just a 16th of an inch, but it otherwise seems sound. No discoloration or eccentric wobble. I'll have someone turn the opposite wheel when I get home to see if it's straight. Would that cause excessive lash and maybe the failure? It looks like the crack over the key had been there for a while since one side of the chunk had grease on it while the other was clean where it sheared.
Sent from my SM-G950U using Tapatalk |
