11-24-2012, 10:02 PM | #1 |
39/40 Ford Headlight interchange
I am new here and have a question will 40 headlights bolt into 39 fenders?
thanks in advance. |
11-24-2012, 10:05 PM | #2 |
Re: 39/40 Ford Headlight interchange
'40 lights are seal beams. No go.
Alan |
11-24-2012, 10:08 PM | #3 |
right, I am talking about removing the whole 39 housing down to the bare fender and installing a 40 headlight assembly in the remaining hole?//?/
11-24-2012, 10:35 PM | #4 |
If they are DeLuxe fenders, they will work.
11-24-2012, 10:53 PM | #5 |
There is a local car for sale, he claims it to be a 40 standard,2 dr sedan, it appears to have 39 head lights, or is this an early 40???? Or has anyone ever seen this before, or is it a 39 with40 paperwork? I guess I should find the VIN is it only on the frame?
11-24-2012, 10:58 PM | #6 |
A couple years ago I had advertised to trade my `35 Cabriolet for a `39 Deluxe Coupe. I got a call from a guy that had a `Nice' `39 Deluxe Coupe. It had `40 headlights and the wrong seats, completely turned me off. Don't get me wrong, `40 headlights on a `40 Ford is great, one of my favorite cars. But it is your car....
Son, you will never blow an engine up in high gear. |
11-24-2012, 11:01 PM | #7 |
I had a 39 deluxe coupe years ago with 40 deluxe headlight doors and seal beams. It's an easy change over.
If the car you are looking at has the "crank out" windshield it's a 39. The 39 also has the wipers at the top of the windshield. The 40 windshield is fixed with a rubber gasket and the wipers are at the bottom of the windshield and mounted in the cowl. This is the easiest way to tell them apart Last edited by TJ; 11-24-2012 at 11:07 PM. Reason: add info |
11-24-2012, 11:07 PM | #8 |
The 39 and 40 are very different cars. 39 has a crank out windshield, the wipers are above the windshield, has no vent windows, has a floor shift, different dash, etc. Many telling features to determine if it is a 39 or 40.
11-24-2012, 11:10 PM | #9 |
Cool thanks for the tips. I will need to take a closer look.
11-25-2012, 06:15 PM | #10 |
keep the 39 Delux headlites, nicer looking than the 40's.
