Old 01-21-2011, 08:14 PM   #1
Alan O'Connell
Default 1935 Rear Axle/drive shaft assembly
I need a 1935 rear axle and drive shaft assembly with radius rods. I don't need the spring or backing plates. 3.54 gear ratio would be preferrable.
Alan O'Connell is offline   Reply With Quote
Old 01-21-2011, 10:01 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: 1935 Rear Axle/drive shaft assembly
Good luck on the 3.54.
Old 01-21-2011, 10:48 PM   #3
X38
Wanted
https://www.fordbarn.com/forum/forumdisplay.php?f=15
X38 is offline   Reply With Quote
Old 01-22-2011, 08:34 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
It took me almost two years to find a set of 3.54's with a ten spline pinion....that I could actually afford. You can buy new reproduction sets with six spline pinions for $350 and convert your driveshaft to six spline. Best bet is to put an ad in the wanted sections on this and other old Ford websites.
John
Old 01-22-2011, 10:37 AM   #5
Andy
35 rear with 3.78's. No spring or radius rods. $200
Andy is offline   Reply With Quote
