Old 11-27-2020, 06:39 PM   #1
36coupe
36coupe's Avatar
Default Replacing grease wide 5 front drums
I cleaned up real nice set of wide five front drums. I had to scoop out what seemed like a 1/2 of a tube of grease out of each one. I cleaned up the bearings and plan pack them and reinstall them with a new seal.
My question is is the cavity between the bearings supposed to be full of grease?
Thanks
Regards,
Lindsay
36coupe is offline   Reply With Quote
Old 11-27-2020, 06:48 PM   #2
Bursonaw
Bursonaw's Avatar
Default Re: Replacing grease wide 5 front drums
No, just grease the bearings. Filling the center cavity does nothing and is just a waste of grease.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 11-27-2020, 07:04 PM   #3
cas3
i use the center of the hub to wipe the excess grease off my fingers. edge of dust cap works good for that too
Old 11-27-2020, 07:15 PM   #4
36coupe
36coupe's Avatar
The grease hadn’t seen the light of day for a long time. It was very black and seemed different from modern wheel bearing grease
Regards,
Lindsay
Old 11-27-2020, 07:59 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
You know, it IS entirely possible that grease is approaching 85 years old. DD
T5 W/TORQUE TUBE
We WILL discover aliens on another planet...and the 'nutsoids' will surely-enough be sending $TRILLION$ of our bucks in aid!
Old 11-27-2020, 08:05 PM   #6
aussie merc
aussie merc's Avatar
fill the center between the cups up to the level of the cups as ford dont use close tolerance slingers in their hubs then fill the cap before reinstalling also fill the back of the seal before installing . see timken's pages for a better set of guides as to install and setup
aussie merc is offline   Reply With Quote
Old 11-27-2020, 09:21 PM   #7
Tinker
Tinker's Avatar
You could always bottle it and sell it on ebay as vintage.
Old 11-28-2020, 10:01 AM   #8
19Fordy
19Fordy's Avatar
Are these the Timken Grease Guidelines mentioned above?
https://www.nodeshk.com/timken/art/g...uidelines.html
Old 11-28-2020, 07:36 PM   #9
aussie merc
https://www.carid.com/images/timken/...structions.pdf Try this there about the easiest to follow ive found basic end game you need endfloat or you will damage the bearing
