Old 11-08-2020, 10:16 AM   #1
rust revival
Default Banjo 39-40 hub flange difference?
I'm going to look at a banjo today for the purpose of needing unpitted axle bells
I'm needing a 39-40 but he thinks the hub Flange on his might be longer because of the drums? And might not be able to use wide 5 drums that I have? I was under the impression that 37-40 was the same?
File Type: jpg Screenshot_20201107_194002_com.android.chrome.jpg (20.0 KB, 29 views)
rust revival is offline   Reply With Quote
Old 11-08-2020, 10:24 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Banjo 39-40 hub flange difference?
The bearing flange areas should be the same - no worries!
Old 11-08-2020, 10:31 AM   #3
rust revival
Great. Thank you
Old 11-08-2020, 10:38 AM   #4
deuce_roadster
deuce_roadster's Avatar
Post 41 axles are longer but the bearing surface is the same.
Old 11-08-2020, 11:15 AM   #5
rich b
rich b's Avatar
Be sure to look at the spring hangers to make sure it is a '37-'40 axle and not a '41 or '42-'48.
