Old 09-30-2019, 07:50 AM   #1
Dak Rat
Default Valve clearance Hot/Cold
I have an Isky 77B cam installed in my 276" 8BA. Specs call for .014 both Int. & Exh. HOT. Since its not possible to adjust the clearance HOT in a FH, what would be the correct clearance to use? I'm thinking about .016, what say the experts?
Dak Rat is offline   Reply With Quote
Old 09-30-2019, 09:15 AM   #2
40 Deluxe
Default Re: Valve clearance Hot/Cold
Surely Isky knows better than to specify a "HOT" clearance spec for a flathead! Maybe should call them for clarification.
Old 09-30-2019, 05:26 PM   #3
Pete
Pete's Avatar
It is .011 and .013 cold.
CORRECTION: The ones I do are set at the above specs.
I got my masters from an original Isky cam with the red steel seal on it, in the mid 50's.
It is important to follow the manufacturer's installation instructions.
Deviating could void the warranty.
Old 09-30-2019, 07:15 PM   #4
Dak Rat
Well, cam card says .014. Have e-mailed Isky, we'll see if they can provide the clearance for cold setting.
Old 09-30-2019, 08:44 PM   #5
RalphM
RalphM's Avatar
Pete,
Is that .011 exhaust and .013 Intake?
I would think the clearance on the exhaust needs to be more than the intake due to the valve getting hotter and expanding more?
RalphM is offline   Reply With Quote
Old 09-30-2019, 08:54 PM   #6
Pete
Pete's Avatar
The intake is ALWAYS given FIRST.
It is etched in stone.
Old 10-01-2019, 07:49 AM   #7
Dak Rat
Got the answer from Isky--there was a misprint on the card that came with the cam. Clearance is .014 both Int. and exh. This is the COLD setting for the 77B cam.
Old 10-01-2019, 11:48 AM   #8
Russ/40
Russ/40's Avatar
I bought the 77B 25 years ago, had the misprint then.
Russ/40 is offline   Reply With Quote
