Old 06-18-2019, 05:34 PM   #1
Cape Codder
Cape Codder's Avatar
Default Problem Horn
I have a horn that looses it's adjustment often, especially during parades. How can I keep it adjusted to the ahooga sound? Is my problem a worn Horn Motor Diaphragm or...........?
Also the horn does not seem the correct ahooga sound. Is this a bad Horn Diaphragm?
Any suggestions or words of instruction would be really appreciated.
Cape Codder is offline   Reply With Quote
Old 06-18-2019, 05:45 PM   #2
Joe K
Joe K's Avatar
Default Re: Problem Horn
Original or Hutchins? Or something else?
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 06-18-2019, 07:38 PM   #3
Cape Codder
Original Spartan
Old 06-18-2019, 08:10 PM   #4
quickchange
quickchange's Avatar
could be repo diaphragm, Thicker than orig so note different, on 6 or 12 volt, ??Adjustments have a spring under it ? screw stripped ? many things, get an exploded view of one may show the problem , all else fails don,t use it as much or drop blue pill in gas tank ,
Winter time in NZ
quickchange is offline   Reply With Quote
Old 06-19-2019, 03:32 AM   #5
chrs1961815
chrs1961815's Avatar
I would say that the screw or the hole is stripped or the threads are not that good. You could try some LIGHT DUTY locktite on the screw to keep it in place if you do not want to fix the horn now, but you probably will as it sounds like there might be something wrong with the diaphragm.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-20-2019, 05:56 PM   #6
Cape Codder
Thanks to [B]quickchange [B] and chris1961815 for your comments and suggestions.
